Ah! Car won't idle! Help! Revs to 1.7k and dies??
Alright, at one point in time, the car was throwing DTCs for MAP and MAF. Which I understood could also mean my Crank Position Sensor was bad too. Replaced CPS and MAP. It's not throwing any codes now.
The way it behaves: you start it, it revs to around 1.7k, then just DIES. New plugs, new fuel pump, I have spark and fuel. No DTCs. Any ideas? I'm at a loss for words here. I tried to switch out my MAF with one from a buddies 8, still no luck. input gentleman? -Adam |
It's possible it could be the ISC.
I would say ISC/IAC first. I just went through this with my car and it ended up being that. Does it stay running if you unplug the MAF? Then plug the MAF back in and see if it stays running if you unplug the ISC/IAC. If it stays running then it is probably the ISC and someone just posted that they are the same as a Dodge part and only $108 new.
ISC/IAC, or Vacuum/Boost Leak.
Originally Posted by delcster27
(Post 8779267)
I'll check out the ISC. Oh, I don't suppose you guys happen to know the part number for the whole accessory belt tensioner assembly? The one that's right next to the oil filter? I snapped it the other day. Gotta love salty German winters. :/ -Adam |
(Post 8779267)
(Post 8779267)
For those out of the loop:
https://www.evolutionm.net/forums/ev...ge-my-isc.html is the thread that contains info about the Dodge part. |
^^^yes that is the thread with the part number
is it in time what happen how did this problem start
^ whaaaaaaa?
Have you checked all your IC pipes along with the IACV yet? |
did you get your car fixed?
bump having the same problem!
| All times are GMT -7. The time now is 04:21 AM. |
