Can't cross 25psi on a ATP GTX35R Kit
Hello!!!
I recently installed the new ATP turbo bolt-on EVO 8 GTX35R kit. The car (EVO 7) has forged .020 Wiseco pistons, Eagle rods, and crank, sotkc sized ferrera SS valves and a set of Tomei type R 270 cams. Its got the drop-in K&N filter and a chinese Greddy Style TB exhaust system. It has a ECUtek flash. My problem is that the engine doesn't want to cross 25 lbs. of boost. The car made 393whp @ 25psi. The kit comes with a 14.7psi internal gate and I got the extra froma boost tee. I tried to get more boost by pulling the vaccum hose to the wastegate actuator but no effect on boost. Any help will be greatly appreciated. I am very new to everything forum wise, but from the reading you guys are a very very informed bunch. |
check for boost leaks...you must have a huge leak somewhere.
I did a boost test up to 3 bar and everything stayed intact. I have atheory that the internal wastegate flap is being blown open by exhust pressure..... Does that make any sense?
Did you try tightening the wastegate actuator.
what are you using for boost control?
are you still using stock intake? |
Try tightening the waste gate acuator. You could go with a MAP down pipe with a tial 38mm gate to control boost better.
what intake r u running? stock rubber one?
with the atp turbo it would seem that the stocker wouldnt work, but you said you have a drop in K&N,.. also what boost controler r u running? |
Waste gate sounds like it's being blown open, try tightening it up.
It wouldn't be a leak because his car would misfire or run really rich
Check your wastegate and if you don't have a boost controller I would get one. You should be able to either change out springs like the forge wastegate or get a stronger wastegate. Make sure ur tune is good got that much boost |
I try that. It does make sense!
try a boost controller and tial wastegate...
| All times are GMT -7. The time now is 02:34 AM. |
