Can't cross 25psi on a ATP GTX35R Kit
Old Feb 13, 2011 | 10:53 AM
fastparts's Avatar
Hello!!!
I recently installed the new ATP turbo bolt-on EVO 8 GTX35R kit. The car (EVO 7) has forged .020 Wiseco pistons, Eagle rods, and crank, sotkc sized ferrera SS valves and a set of Tomei type R 270 cams. Its got the drop-in K&N filter and a chinese Greddy Style TB exhaust system. It has a ECUtek flash.
My problem is that the engine doesn't want to cross 25 lbs. of boost. The car made 393whp @ 25psi. The kit comes with a 14.7psi internal gate and I got the extra froma boost tee.
I tried to get more boost by pulling the vaccum hose to the wastegate actuator but no effect on boost. Any help will be greatly appreciated.
I am very new to everything forum wise, but from the reading you guys are a very very informed bunch.
Old Feb 13, 2011 | 10:55 AM
erald01's Avatar
check for boost leaks...you must have a huge leak somewhere.
Old Feb 13, 2011 | 11:03 AM
fastparts's Avatar
I did a boost test up to 3 bar and everything stayed intact. I have atheory that the internal wastegate flap is being blown open by exhust pressure..... Does that make any sense?
Old Feb 13, 2011 | 11:19 AM
fastparts's Avatar
Old Feb 13, 2011 | 12:46 PM
Evotech8's Avatar
Did you try tightening the wastegate actuator.
Old Feb 13, 2011 | 12:55 PM
05VIII's Avatar
what are you using for boost control?
are you still using stock intake?
Old Feb 13, 2011 | 02:51 PM
EvoDom's Avatar
Try tightening the waste gate acuator. You could go with a MAP down pipe with a tial 38mm gate to control boost better.
Old Feb 13, 2011 | 02:54 PM
still*boostn's Avatar
what intake r u running? stock rubber one?
with the atp turbo it would seem that the stocker wouldnt work, but you said you have a drop in K&N,..
also what boost controler r u running?
Old Feb 13, 2011 | 03:48 PM
Boost Demon's Avatar
Veteran: Air Force
Waste gate sounds like it's being blown open, try tightening it up.
Old Feb 13, 2011 | 08:11 PM
steven121's Avatar
It wouldn't be a leak because his car would misfire or run really rich
Check your wastegate and if you don't have a boost controller I would get one. You should be able to either change out springs like the forge wastegate or get a stronger wastegate. Make sure ur tune is good got that much boost
Old Feb 14, 2011 | 02:08 AM
fastparts's Avatar
I try that. It does make sense!
Old Feb 14, 2011 | 07:18 PM
mc14's Avatar
try a boost controller and tial wastegate...
fabiano
Mar 13, 2016 01:01 PM
wrx_ua
Jun 23, 2015 03:20 PM
TDV
20
Oct 10, 2013 08:31 AM
MRadjahoe
Mar 31, 2012 10:56 AM
Mines Evo IX
Sep 2, 2007 11:04 PM
