-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   My evo won't start after rebuild..video included (https://www.evolutionm.net/forums/evo-general/580633-my-evo-wont-start-after-rebuild-video-included.html)
RallySport9 Oct 24, 2011 11:28 AM
just rebuilt my engine so i know theres nothing wrong with it, theres gas, alternator is fine, i thought it may be my immobilizer cuz some of its connection wires are cut but i don't think it is. It turns over sounds like its about to start..but can't :confused: has anyone had this same experience or know what the problem may be based on the video i uploaded? your help would be very much appreciated. Thanks. I can give more details if you need them.
http://www.youtube.com/watch?v=zJ6FUvDOAIE
stamlon Oct 24, 2011 11:30 AM
check your timing.
CtSilver03Evo Oct 24, 2011 11:36 AM
Originally Posted by stamlon (Post 9694556)
check your timing.
I would start by making sure your MAF is plugged in, your crank position sensor, cam angle sensor, etc...
Then, if all is... pull hte timing covers off and double-check all your timing marks. Sucks, but that's prolly the issue. (Assuming you didn't change other things during the build - fuel, etc...)
4RETECH Oct 24, 2011 11:55 AM
If this was a build. check to make sure your crank trigger plate is not on backwards and also the cam sensor trigger is not on backwards.
gsrboi80 Oct 24, 2011 12:09 PM
Can you explain this further what wires are cut? Are they the same key/ECU that were previously with the car?
RallySport9 Oct 24, 2011 04:21 PM
yes, the same key/ecu its all stock. the immobilizer is an aftermarket one from insurance and there are what appears to be 3 thicker black wires coming out of the immobilizer device that are cut...i am also currently checking all sensors.
Pssst Oct 24, 2011 06:51 PM
Try holding your gas pedal to the floor and cranking it... kills the injectors... or is that just a dumb idea :confused:
truevo7 Oct 25, 2011 06:56 PM
double check all sensors, but i def would check timing first. if its off you don't want to risk damage
wht95scort Oct 25, 2011 07:42 PM
Check for spark and engine codes
EatSleepBoost Oct 25, 2011 08:19 PM
have you done the basic checks yet? Spark tester, fuel pressure, compression. Are your plug wires hooked up properly? I know of a few people that have mixed those up
