My evo won't start after rebuild..video included
Old Oct 24, 2011 | 11:28 AM
RallySport9's Avatar
just rebuilt my engine so i know theres nothing wrong with it, theres gas, alternator is fine, i thought it may be my immobilizer cuz some of its connection wires are cut but i don't think it is. It turns over sounds like its about to start..but can't has anyone had this same experience or know what the problem may be based on the video i uploaded? your help would be very much appreciated. Thanks. I can give more details if you need them.
http://www.youtube.com/watch?v=zJ6FUvDOAIE
Old Oct 24, 2011 | 11:30 AM
stamlon's Avatar
check your timing.
Old Oct 24, 2011 | 11:36 AM
CtSilver03Evo's Avatar
Originally Posted by stamlon
check your timing.
I would start by making sure your MAF is plugged in, your crank position sensor, cam angle sensor, etc...
Then, if all is... pull hte timing covers off and double-check all your timing marks. Sucks, but that's prolly the issue. (Assuming you didn't change other things during the build - fuel, etc...)
Old Oct 24, 2011 | 11:55 AM
4RETECH's Avatar
If this was a build. check to make sure your crank trigger plate is not on backwards and also the cam sensor trigger is not on backwards.
Old Oct 24, 2011 | 12:09 PM
gsrboi80's Avatar
Can you explain this further what wires are cut? Are they the same key/ECU that were previously with the car?
Old Oct 24, 2011 | 04:21 PM
yes, the same key/ecu its all stock. the immobilizer is an aftermarket one from insurance and there are what appears to be 3 thicker black wires coming out of the immobilizer device that are cut...i am also currently checking all sensors.
Old Oct 24, 2011 | 06:51 PM
Pssst's Avatar
Try holding your gas pedal to the floor and cranking it... kills the injectors... or is that just a dumb idea
Old Oct 25, 2011 | 06:56 PM
truevo7's Avatar
double check all sensors, but i def would check timing first. if its off you don't want to risk damage
Old Oct 25, 2011 | 07:42 PM
wht95scort's Avatar
Check for spark and engine codes
Old Oct 25, 2011 | 08:19 PM
EatSleepBoost's Avatar
have you done the basic checks yet? Spark tester, fuel pressure, compression. Are your plug wires hooked up properly? I know of a few people that have mixed those up
evolverx
Future Lancer / Evo Models
Mar 6, 2018 05:18 AM
Hamman
Outlander Sport
Dec 28, 2014 05:58 AM
E-Spec@Tach Motor Works
Dec 22, 2011 07:18 AM
