Stock cams?
I just took my car to replace head gasket does anyone know if these are stock cams or aftermarket?
They have stuff saying k 6 and 6b24 I will post pic later |
If they are stock there will be holes that have been drilled into the camshafts. Aftermarket ones will be solid.
Oh these have holes in the cams...
Stock
What all do i need to do to install hks or gcs? Any timing or anything like that??
it depends on what size cams you want to put in. if your going with a 264 or the gsc S1's then you will be ok with just putting the cams in without anything else if your on a budget. If you want a 272 then its smart to upgrade the springs retainers and seats. and might as well replace the timing belt while at it
and yeah iam replacing the timing belt and head gasket too and all those belts around there.... what are best ones that dont need to retainers replace? i want to buy some..
Ok so i just took the head off and the head gasket is blowen on the side... The block or the head dont look like it is damaged. Do i need to do anything else to the head?
Originally Posted by evoboy2012
(Post 9995343)
get gsc stage1 cams.
okay my friend will go and take it to a machine shop to see if they can check it.
http://i1221.photobucket.com/albums/...0-05-30_79.jpg
http://i1221.photobucket.com/albums/...-05-25_386.jpg http://i1221.photobucket.com/albums/...0-03-32_70.jpg http://i1221.photobucket.com/albums/...-01-55_448.jpg These are the cams and cam gears, i looked at some other cams online and the gsc 1 look like these are these stock or not? |
>.< re-read previous posts in this thread
I did, but i saw that gsc 1-2-3 have holes in them. so does this one... is it stock or not?
Stock hollow cams (They are NOT DRILLED, jeez). You should get your head/block machined, but at the very least have it checked.
