Stock cams?
Old Feb 26, 2012 | 08:14 AM
evoboy2012's Avatar
Stock cams?
I just took my car to replace head gasket does anyone know if these are stock cams or aftermarket?
They have stuff saying k 6 and 6b24
I will post pic later
Old Feb 26, 2012 | 08:18 AM
evo8426's Avatar
If they are stock there will be holes that have been drilled into the camshafts. Aftermarket ones will be solid.
Old Feb 26, 2012 | 08:33 AM
evoboy2012's Avatar
Oh these have holes in the cams...
Old Feb 26, 2012 | 08:37 AM
4RETECH's Avatar
Stock
Old Feb 26, 2012 | 09:02 AM
evoboy2012's Avatar
What all do i need to do to install hks or gcs? Any timing or anything like that??
Old Feb 26, 2012 | 09:05 AM
silver9mr's Avatar
it depends on what size cams you want to put in. if your going with a 264 or the gsc S1's then you will be ok with just putting the cams in without anything else if your on a budget. If you want a 272 then its smart to upgrade the springs retainers and seats. and might as well replace the timing belt while at it
Old Feb 26, 2012 | 01:27 PM
evoboy2012's Avatar
and yeah iam replacing the timing belt and head gasket too and all those belts around there.... what are best ones that dont need to retainers replace? i want to buy some..
Old Feb 26, 2012 | 03:18 PM
evoboy2012's Avatar
Ok so i just took the head off and the head gasket is blowen on the side... The block or the head dont look like it is damaged. Do i need to do anything else to the head?
Old Feb 26, 2012 | 04:53 PM
4RETECH's Avatar
Straight edge the block and head. Check clearances or it will happen again.
Old Feb 26, 2012 | 05:41 PM
sujinX's Avatar
get gsc stage1 cams.
Old Feb 26, 2012 | 10:54 PM
evoboy2012's Avatar
okay my friend will go and take it to a machine shop to see if they can check it.
Old Feb 26, 2012 | 11:24 PM
evoboy2012's Avatar
These are the cams and cam gears, i looked at some other cams online and the gsc 1 look like these are these stock or not?
Old Feb 26, 2012 | 11:47 PM
SDevo13's Avatar
>.< re-read previous posts in this thread
Old Feb 26, 2012 | 11:56 PM
evoboy2012's Avatar
I did, but i saw that gsc 1-2-3 have holes in them. so does this one... is it stock or not?
Old Feb 27, 2012 | 12:03 AM
boostless's Avatar
Stock hollow cams (They are NOT DRILLED, jeez). You should get your head/block machined, but at the very least have it checked.
