-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   When I fill up gas,EVO doesn't start up! HELP (https://www.evolutionm.net/forums/evo-general/616338-when-i-fill-up-gas-evo-doesnt-start-up-help.html)
Evoixjohn Jun 17, 2012 03:19 PM
So every time i fill up some gas the car doesn't wanna fire up.I would have to step on the gas pedal for it to start up.
What would be the solution? i was thinking a bad fuel pump,just got it too(walbro 255)
*causing idle issue( already changed idle Speed Control Motor)
HELP:confused:
Evoixjohn Jun 18, 2012 04:46 AM
Anyone??BUMP
VAPyro Jun 18, 2012 02:54 PM
I have the same problem as you, or at least very similar.
After I gas up it will sorta stutter, sometimes stall. Usually I just push the clutch in and let it run, the idle will smooth out after about 45 seconds or so.
Unfortunately I don't have an answer for you as far as the cause, but I would think if it was a fuel pump you would have problems other times as well right?
BoostInside Jun 18, 2012 02:57 PM
Maybe flip the ignition to "ON" for a few seconds before trying to turn it over? to let the pump prime up first? Just a guess / .02
st00pidct9a Jun 18, 2012 03:05 PM
x2
Chef-j Jun 18, 2012 03:44 PM
How old is your injectors? Maybe try chevron fuel injector cleaner.
Revo15 Jun 18, 2012 03:51 PM
Start by Testing ur fuel pump, FPR & injectors then go from there..
Evoixjohn Jun 18, 2012 06:45 PM
It doesn't even prime when the ignition is ON
Evoixjohn Jun 18, 2012 06:47 PM
Gotta burn up some gasoline before pulling out the fuel pump lol it's on full tank.
NOMIEZVR4 Jun 18, 2012 06:53 PM
I dont think he is referring to pull out the pump. What i would suggest is to take off the rear seat , put your ear near the pump area. Have someone turn the ignition on and off . If you hear the pump great, its priming.
Now does this only happen everytime you fill up the tank only? Have you tried not filling it to the top? If so, does it still happen?
If this happens everytime you start the car then I would take out the connector from the fuel pump housing and test to see if power is coming to the connectors when you turn the key on.
Start from there then move your way towards the front of the car...
Evoixjohn Jun 18, 2012 07:28 PM
Everytime I fill up on gas,didn't matter how much i added. This never happen with the stock pump,usually I can hear the pump prime from the driver seat.
Thanks for the help guys! Gotta burn some gas first
Evoixjohn Jun 20, 2012 05:52 PM
UPDATE: Changed *new fuel pump walbro 255* *fuel pressure regulator *
I can hear the pump running and priming i have no other clue on what to do! Is it because i'm running GSC 274/274,Ams F1-i intake manifold? Low vacuum? please chime in guys i'm stuck:confused:
Really not liking it when i'm sitting at the pump and people starring WTF is wrong with your car!:sad:
Chef-j Jun 20, 2012 06:51 PM
Have you try check injectors or use cleaner?
Or... Maybe evap system? If then...that should throw code. Hummmm
Evoixjohn Jun 20, 2012 08:26 PM
Yep already tried lucas fuel injector cleaner:dunno:
spoolinx Sep 5, 2013 11:37 AM
Sorry old thread, but I need help also.
Did you ever figured out the problem???
