When I fill up gas,EVO doesn't start up! HELP
Old Jun 17, 2012 | 03:19 PM
Evoixjohn's Avatar
So every time i fill up some gas the car doesn't wanna fire up.I would have to step on the gas pedal for it to start up.
What would be the solution? i was thinking a bad fuel pump,just got it too(walbro 255)
*causing idle issue( already changed idle Speed Control Motor)
HELP
Old Jun 18, 2012 | 04:46 AM
Evoixjohn's Avatar
Anyone??BUMP
Old Jun 18, 2012 | 02:54 PM
VAPyro's Avatar
I have the same problem as you, or at least very similar.
After I gas up it will sorta stutter, sometimes stall. Usually I just push the clutch in and let it run, the idle will smooth out after about 45 seconds or so.
Unfortunately I don't have an answer for you as far as the cause, but I would think if it was a fuel pump you would have problems other times as well right?
Old Jun 18, 2012 | 02:57 PM
BoostInside's Avatar
Maybe flip the ignition to "ON" for a few seconds before trying to turn it over? to let the pump prime up first? Just a guess / .02
Old Jun 18, 2012 | 03:05 PM
st00pidct9a's Avatar
x2
Old Jun 18, 2012 | 03:44 PM
Chef-j's Avatar
How old is your injectors? Maybe try chevron fuel injector cleaner.
Old Jun 18, 2012 | 03:51 PM
Revo15's Avatar
Start by Testing ur fuel pump, FPR & injectors then go from there..
Old Jun 18, 2012 | 06:45 PM
Evoixjohn's Avatar
It doesn't even prime when the ignition is ON
Old Jun 18, 2012 | 06:47 PM
Evoixjohn's Avatar
Gotta burn up some gasoline before pulling out the fuel pump lol it's on full tank.
Old Jun 18, 2012 | 06:53 PM
NOMIEZVR4's Avatar
I dont think he is referring to pull out the pump. What i would suggest is to take off the rear seat , put your ear near the pump area. Have someone turn the ignition on and off . If you hear the pump great, its priming.
Now does this only happen everytime you fill up the tank only? Have you tried not filling it to the top? If so, does it still happen?
If this happens everytime you start the car then I would take out the connector from the fuel pump housing and test to see if power is coming to the connectors when you turn the key on.
Start from there then move your way towards the front of the car...
Old Jun 18, 2012 | 07:28 PM
Evoixjohn's Avatar
Everytime I fill up on gas,didn't matter how much i added. This never happen with the stock pump,usually I can hear the pump prime from the driver seat.
Thanks for the help guys! Gotta burn some gas first
Old Jun 20, 2012 | 05:52 PM
Evoixjohn's Avatar
UPDATE: Changed *new fuel pump walbro 255* *fuel pressure regulator *
I can hear the pump running and priming i have no other clue on what to do! Is it because i'm running GSC 274/274,Ams F1-i intake manifold? Low vacuum? please chime in guys i'm stuck
Really not liking it when i'm sitting at the pump and people starring WTF is wrong with your car!
Old Jun 20, 2012 | 06:51 PM
Chef-j's Avatar
Have you try check injectors or use cleaner?
Or... Maybe evap system? If then...that should throw code. Hummmm
Old Jun 20, 2012 | 08:26 PM
Evoixjohn's Avatar
Yep already tried lucas fuel injector cleaner
Old Sep 5, 2013 | 11:37 AM
spoolinx's Avatar
Sorry old thread, but I need help also.
Did you ever figured out the problem???
