-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   Battery relocated to trunk, now won't turn over (https://www.evolutionm.net/forums/evo-general/651061-battery-relocated-trunk-now-wont-turn-over.html)
escape1221 Mar 21, 2013 05:53 AM
2 Attachment(s)
Alright guys I installed the Taylor Battery Relocation Kits 48103 to the trunk.(http://www.summitracing.com/parts/TA...n/?prefilter=1)
But when I tried to start my car it wouldn't turn over? I'm getting power - lights, door lock, windows etc etc. But it's really bipolar, I tried starting it a couple more times and after the 4th attempt it started. Next day same thing. I've tried grounding it in a couple different places as shown in the pics, it's 1-gauge wire, and my battery's cold cranking amperage is 600 and 750 normal temp. I haven't tested how much juice it has left but I'm pretty sure that's not the problem. Any ideas?
escape1221 Mar 21, 2013 05:57 AM
1 Attachment(s)
2nd grounding attempt
fastyouth1313 Mar 21, 2013 05:57 AM
how was the connection made to the starter wire? crimmped or sodlered?
escape1221 Mar 21, 2013 06:12 AM
Crimmped
escape1221 Mar 21, 2013 06:17 AM
1 Attachment(s)
it's the heavy duty screw on ones
fastyouth1313 Mar 21, 2013 06:20 AM
i would say to solder the starter wire. crimmping on large/Long gauge wire is not good.
blowngasket Mar 21, 2013 06:28 AM
Run 2 Ground wires :o
And dont piggy back them, Go right from the terminal for each of them.
fastyouth1313 Mar 21, 2013 06:33 AM
Run 2 wires off the grounding terminal of the battery to 2 separate points in the trunk?
escape1221 Mar 21, 2013 08:02 AM
I just checked my battery voltage and it's 12.58 volts. That should be enough to start the car right? And where are some of the other places people have grounded the battery in the trunk?
chu Mar 21, 2013 08:05 AM
Yes, that should be enough. You should sand the paint off your ground points. Proper grounding is very important.
escape1221 Mar 21, 2013 08:08 AM
I did that in 2 different places. And I did two seperate grounds to the battery and it still wont start?
fastyouth1313 Mar 21, 2013 08:17 AM
did you try 2 grouding points off of one battery terminal?
you should have someone theck the battery voltage when your cranking it to see what you get.
chu Mar 21, 2013 08:29 AM
I can't say this with certainty, but I think you have the power line connected to the top of the fuse link, which is not letting enough amps through. Try conneting the bottom where the other two are.
escape1221 Mar 21, 2013 08:46 AM
That's funny you say that cause a couple hours ago I thought of that and switched it around but it still wont turn over? :-(
OhhBx Mar 21, 2013 09:51 AM
https://www.evolutionm.net/forums/ev...elocation.html
