Quick plasti dip question
well the DYC forums were of no help, so I was wondering if anyone here had an opinion, I'm not sure if this is the correct forum to be posting in. I plan on plasti dipping my wheels, but I have an electric sprayer and about 2 gallons of plasti dip left. Will spraying the wheels with the sprayer be as effective as using a can of compressed plasti dip because of the strange spray angles? Also as another question, does anyone have an idea of how I can get a good angle on the roof with a sprayer?
1 Attachment(s)
I did my car with their hvlp sprayer.
when doing the wheels make sure you take them off the car and lean them on a wall and youll be good with either the can or sprayer, remember multiple light coats will be the best with 15 min between each coat. When i sprayed my roof i stood on a ladder and then tilted the car at a fairly steep angle,(jack stands on one side). What type of sprayer are you using? In my sprayer you can adjust the paint pickup in the canister by rotating a straw. |
Originally Posted by xXANCHORMONXx
(Post 10741435)
1 Attachment(s)
I dipped my roof a few days ago with a sata jet gravity feed. I masked my car off. Took like 15 minutes to tape and cover in plastic. Then I began spraying. Here is the final product
Attachment 278395 |
Originally Posted by mrdrvr
(Post 10741696)
http://i1357.photobucket.com/albums/...ps69f8263a.jpg |
bumping
You don't even need to take the wheels off the car if your doing plasti dip. Tape off the body and stuff that you don't want to clean up later. As you know if you mess up just peel off and go at it again. Have fun
Originally Posted by mossontree
(Post 10742170)
Did you use any sort of jacking method? It how did you get your spraying done? Also are those wheels plasti dipped? Did you take the wheels off or leave them on? Did you use the sprayer for them?
Just a heads up guys, I work for Wagner in the technical service department, and NONE of our consumer units are safe to use with Plastidip.
The reason being, none of the turbines used in the HVLP sprayers are spark contained, nor are the armatures in the cup guns. Plastidip is one of the worst coatings on the market as far as a flashpoint is concerned, and it produces enough vapor to combust with a spark at NEGATIVE 20 degrees Fahrenheit. For the record, gasoline is -45F. Consider yourself to basically be spraying gasoline into the air with something that is capable of creating a spark. So please PLEASE be safe and use a proper setup for spraying this stuff, at the very minimum an HVLP conversion gun with the compressor in another room entirely, or even better a spark contained compressor. Just because Johnny Bravo with his Honda Civic down the street did it in his garage with a Control Spray and didn't blow himself up doesn't mean you won't. Believe me, I do realize that our consumer HVLP units spray this stuff like a dream, but it's sure as hell not worth risking your property, health, or possibly even life over. And before anyone says anything, yes, I know DYC uses one of our Control Spray units in their videos. They were marketing it on their site for a while and we had to issue a cease and desist notice over it because of the risks. |
1 Attachment(s)
I used white plastidip on my wheels and I have no regret. I used it straight from the spray can though, looks great and has yet to peel off. Just saying. That's my personal opinion on it. A cheap DIY.
Originally Posted by cmspaz
(Post 10744728)
THANK YOU CMSPAZ!!!
Need to let some friends know about this potentially HUGE danger! {thumbup} |
Originally Posted by basher519
(Post 10745064)
THANK YOU CMSPAZ!!!
Originally Posted by bitterchild
(Post 10744907)
Good to know. Is the Earlex 3500 DYC is not selling safe for use w/ plastidip?
But just taking a look at it, it doesn't appear to be, as they don't mention it and it would be a huge selling point. I would call Earlex and ask them, and if they say it's not, be sure to notify them that DYC is selling it specifically for use with low flashpoint materials. Any GOOD tech rep is going to make sure that info gets to the right people, at the very least a supervisor. |
Aww, look at Spaz all up in here with knowledge and ****.
Why not just Vinyl wrap it? The pricing is similar ans there is much less prep work!
http://www.ebay.com/itm/Matte-Flat-Black-Air-Release-Vinyl-Wrap-Hood-Roof-Trunk-Door-Bumper-60-x60-/320946821774?pt=Motors_Car_Truck_Parts_Accessories&hash=item4ab9ebda8e&vxp=mtr |
