-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   SpoolinUp COP Swap - Engine Won't Turn Over (https://www.evolutionm.net/forums/evo-general/730646-spoolinup-cop-swap-engine-wont-turn-over.html)
mdknutsen Jul 1, 2016 08:22 PM
I just did a COP install and the engine won't turn over. It cranks but doesn't catch. Swapping back to OEM will get it to turn over immediately. Any ideas?
Tekniq Jul 2, 2016 09:15 AM
Did you plug in both sides?
Did you get it from the website or 2nd hand?
mdknutsen Jul 2, 2016 11:40 AM
Got it from the website but it is the kit. I'm going to test it to make sure all of the wiring is good.
mdknutsen Jul 2, 2016 04:25 PM
Tested the wiring and it's all correct and working. It's looking like the coils.anybody know a quick way to test the coils?
dr_latino999 Jul 3, 2016 02:15 PM
Did you check the ignition fuse? Switching to the COP blows the OEM 10, it's recommended to switch to a 20 amp.
mdknutsen Jul 3, 2016 02:37 PM
I used the 15a fuse that came with it. Didn't blow the fuse though.
llDemonll Jul 5, 2016 07:51 AM
If you bought new the chances of more than one ignition coil being dead are next-to-nothing. The engine will run on three cylinders, and probably even manage to run on two
check to make sure you've got the correct plugs hooked up and they're not on backwards.
mdknutsen Jul 6, 2016 10:28 PM
Plugs are correctly wired. Anybody have any tips to test this?
heavens turbo Jul 9, 2016 12:26 AM
did you buy the new coil set or the used coil set? you can check the resistance in the coils with an ohmmeter. if the coils show open, they are bad. most likely, if you can swap the old ones with no problems, you have a wiring problem, or all the coils are bad. it's very rare to have 4 bad coils, but if you bought the used cop kit, you might have just got a bum set. I heard matt at spoolin up is very good about service, so I would contact him for some ideas. I also have the spoolin up kit, and it has been awesome. I bought the new coil kit.
mdknutsen Jul 9, 2016 10:24 AM
Thanks. I'm going to check the coils. I got what I thought was a set of new densos but showed up in some knockoff looking package.
llDemonll Jul 11, 2016 09:14 AM
was the unit not assembled? if you bought from spoolinup it should have been fully assembled
jdmauto Jul 11, 2016 08:37 PM
check if its sparking with the coils of, connected to a spark plug, out the engine head close to anything grounded.
iLLevo_ Jul 12, 2016 05:46 AM
mdknutsen Jul 12, 2016 05:51 AM
Spoolinup sells a diy kit
