Top speed in each gear?
Does anyone know the top speed in each gear if you shift at redline (7k rpms)?
1st: 30 mph 2nd: 59 mph 3rd: 83 mph? 4th: 110 mph? 5th: 157 mph? |
Those seem pretty close to what I remember them being while driving, although I've never gone that high in 5th.
from what ive heard/exprierienced 4th goes to 120 :crap:
4th redlined is 120, 5th at 6800rpm or so is 156
This will show yu excatly what speed each gear goes to:
5th v.s. 6th https://www.evolutionm.net/forums/at...chmentid=41399 |
5th v.s. 6th https://www.evolutionm.net/forums/at...chmentid=41399 thats a lot closer to what i was thinking. I knew 1st was into 4 mph, 2nd over 60 mph and 3rd at 90 mph, 4th at 120 5th i never toped out in. |
so.....these are all stock specs?
these will vary depending on whether you are talking about redline (7000) or fuel cut (75-7600). And yes, these are all stock specs.
Well, unless you get a chip that up's the fuel cut, change the tranny, or change the diffs, no amount of mods will affect the top speeds in each gear
not true.....i have several mods and a apexi power fc ....which resulted in a much higher top speed in 5th gear... |
i am building my car for top speed....so i have gone around and around about this subject....i am about to install the hks final drive 4.11...so i can be geared for 200mph...
Thanx Chris |
If you change your final drive, 5th gear, or rev limiter, then your top speed will have a higher LIMIT. But if you don't make the power to over come the drag (IE) then it doesn't matter what gears or rev limit increase you have. My 2 cents.. |
Originally Posted by 2k4EvoVIII
Where and how much did you find this gear?
Thanx Chris well heres the deal......the hks kansai service final drive 4.11 runs about $800.00 ..... but the good news is the that another member on this board hookt me up with som info....the ratio of the 2000 mitsubishi GALANT is the ratio of 4.111 of the evo and it fits exactly into the tranny....and the part from mitsu is only about 200.00 |
