EGT Gauge Question
Old Oct 22, 2004 | 07:21 AM
NYREDEVO's Avatar
EGT Gauge Question
Anyone with an eGT INSTALLED been to a dealership since they did it?? have they given you any problems? Just wanted to make sure before I do any drilling into things LOL. Anyone have a install w/pics?
Old Oct 22, 2004 | 07:57 AM
NYREDEVO's Avatar
Nobody has been to a dealership for any service with an EGT installed??
Old Oct 22, 2004 | 08:23 AM
AUSS1E's Avatar
Im sure they have it may just take more than 36 min for them to see this post and respond
Old Oct 22, 2004 | 08:27 AM
NYREDEVO's Avatar
yea im impatient
Old Oct 22, 2004 | 08:46 AM
speedomodel's Avatar
I have 4 EGT's (and many other probes) and my dealership is cool with it. Then again, I've been going there for 10 years.
Old Oct 22, 2004 | 09:09 AM
NYREDEVO's Avatar
great pics! What else u have installed?
Old Oct 22, 2004 | 09:12 AM
evo82003's Avatar
nice pics,thats a clean engine
Old Oct 22, 2004 | 09:58 AM
Evolboost's Avatar
Looks great speedomodel.
Old Oct 22, 2004 | 10:53 AM
M3lachsilber's Avatar
choad
Moving to How To's..Questions.
Thanks.
Old Oct 22, 2004 | 11:35 AM
Thanks.
Other gauges: boost, intake air temp, oil temp, water temp, oil pressure, and volts. Gauges are SPA Technique dual digitals. As long as the install is clean, you shouldn't get much flak from your dealer. Also, take your time properly welding a bung into the exhaust manifold for the sensor.
Old Oct 22, 2004 | 09:57 PM
JTB's Avatar
JTB
No problems from my local dealer.
Originally Posted by speedomodel
Thanks.
I installed mine with a pipe thread tap per Evomoto's installation directions. You should definitely weld on a tubular manifold but I was under the impression that you shouldn't weld on the cast manifold?
4 EGTs? Are you worried about a clogged injector? Cool setup but isn't that a little bit of overkill?
Old Oct 22, 2004 | 10:08 PM
lil'evil_evo's Avatar
Old Oct 25, 2004 | 07:41 AM
Originally Posted by JTB
NYou should definitely weld on a tubular manifold but I was under the impression that you shouldn't weld on the cast manifold? 4 EGTs? Are you worried about a clogged injector? Cool setup but isn't that a little bit of overkill?
Yeah, it's definitely overkill. The idea was that when I start doing some serious tuning, I can see whether a particular cylinder is running too lean. I'll talk to my mechanic today and get a proper response to your other questions.
Old Oct 25, 2004 | 05:45 PM
Right on, I had thought the bungs were welded on, but they were simply threaded in after drilling the manifold.
Old Oct 26, 2004 | 11:12 AM
mr0072003's Avatar
How did you get the guages on the Center consoel were the ash tray is. I would love to see that up close.
thanks
