Installing front sensors for laser jammer sensors???
I'm not sure if this is posted anywhere else. I just got the Escort Shifter ZR3 and I was wondering if anyone had any tips on where to place the front sensors. I plan to put them behind the front grill on the sides of the Mitsu symbol, but I'm not sure if thats the best place to put them. If anyone could recommend a good place I would appreciate it. (pics would help as well). Thanks.
where did you end up putting them??? I'm wondering the same thing.. . . .since the plate is a bit off to the side, and the front sensors are supposed to be close to the plate. . . .
ANOTHER QUESTION:
Is there a way to run a wire from the trunk to the front, since the trunk is sealed off and doesn't have a 60-40 split?? The rear sensor has to get routed to the panel which is in the cabin. . .
ANOTHER QUESTION:
