Lower damper removal
Old Jan 17, 2005 | 11:26 AM
MAAGJR's Avatar
Unhappy Lower damper removal
Hello as i was changing cams on my evo the timing belt tool broke as i was pulling it out.
The install went OK until that point
If I see throght the hole where the tool gets inserted i could see the little piece just at the end of it but not well enought to remove with a magnet
I will be removing the lower plastic cover to be able to see much better, but i need to remove this damper wheel
Any sugestions?
thanks
