rear sway bar install someone?
Old Apr 14, 2005 | 10:29 PM
LanEvoDemon's Avatar
Can someone do an install for evo rear sway bar, specifically cusco 23mm one. The link/sticky for Vivid racing doesn't work.
Thanks
Old Apr 15, 2005 | 08:00 AM
GVR-4's Avatar
RRE has a some pictures and hints up on their web page.
When I just installed my Progressive/RRE bar last week what I found is that you have to drop the lower, drivers side lateral link to be able to snake the old bar out and the new bar in. The link I'm referring to is the one to which the bottom of the shock is attached. Remove the bolt through the bottom of the shock, and the bolt that links the arm to the wheel hub. Let it drop down so that it is nearly vertical and the sway bar will come right out.
You may need to support the wheel with a jack to get the bolts back into the shock and hub.
Took me about 1 hour taking my time. Could probably now do it in half of that.
Mark
Old Apr 16, 2005 | 07:15 PM
cool thanks a lot. i figured you had to drop the lateral links. hoped it wasn't as complicated as the front sway bars.
