How-to: Autopower bolt-in rollbar install
This is a rollbar, not a rollcage. A minimal rollcage would have beams extending forward from the main hoop, a horizontal bar across the top just behind the windshield, and door beams going from the main hoop to the forward beams. Furthermore in addition to how many "points" the rollcage must have, there will be requirements as to cage material, tubing size and thickness, type of welding and installation (bolt-in vs. welded). Consult the appropriate rulebooks from your racing organization for full details.
I talkex to the guys from autopower at SEMA today. They said you can buy this and add the extension to make it a full cage. Too meet NHRA rules you just have to weld the end points in instead of drilling.
ERIK
ERIK
Thanks for the thread - it was very helpful. I added grade 8 bolts - and had the bar powdercoated to match the interior.
IMPORTANT: The bar can only be placed in the car THROUGH THE PASSENGER SIDE - the is because of the cross brace. Dont waste your time trying trough the other side.
Looks nice; not sure about powdercoating--a lot of people won't powdercoat rims because it can weaken them and I wonder if the same might be true for a rollbar. My rollbar is a bit scratched up from me loading and unloading a racing jack into the rear footwell and occasionally hitting the bar, and the IOPort camera mount I have on the diagonal brace put a ton of scratches on the bar since it's metal-on-metal clamped. Ah well, for me the bar is for safety, not show so I don't care. The blue looks good though. :thumbsup:
Which type of roll cage is stronger? A bolt-in cage or a custom welded cage? I'm reffering to the Autopower full bolt-in cage http://www.ioportracing.com/Merchant...ory_Code=AP952 .
Generally a welded cage will be stronger, and a custom one even more so... but it depends who designs the cage and who welds it. If that's the route you decide to take, find someone who has a lot of experience in both.
Thanks vtluu, im really leaning towards a custom weld-in cage with atleast 8 points and front door gaurds. Just not sure where i can find a fabrication shop in my area since im in NYC and NJ area.
Originally Posted by 'ringmeister
-you don't have to worry about powder coating steel; you only heat to about 450F to melt the powdercoat media, and that won't bother steel.
Originally Posted by timmiii
Roll cages are street legal?
Rollbars are perfectly fine of course.
Originally Posted by johnnysixer
What is the flat bar connecting to the diagonal bar for?
i'll bump this thread, was a good informative read before i put mine in this weekend.
