Autometer Air?fuel Gauge
Old May 14, 2005 | 07:13 AM
ralliart1979's Avatar
Autometer Air/fuel Gauge
Just a little tip when installing your air fuel gauge, This install means you have to tap into the bleu signal wire. make sure you sauder the wires together.
You will have four wires,
2 Black-ground
1 White- Heater wire
1 Blue-Signal Wire
If you tap the wrong wires you will damage your o2 sensor.
Old May 27, 2005 | 09:49 PM
chinto's Avatar
two black wires are no both ground!!
one black is 12 volt one black is ground white is ground blue is sensor
use the two black wires for ground white wire for ground and blue for sensor good luck
or thats how it is for the primary o2 sensor that screws into the o2 houseing by the turbo in the front of the car.
