URGENT HELP NEEDED (Brakes)!!!
Old May 28, 2005 | 10:46 AM
KTT's Avatar
KTT
I can't push the piston in on my rear right brakes in order to fit to new brake pads in. Help!!! Please!!!
Old May 28, 2005 | 11:07 AM
chinto's Avatar
get a pad spreader or make sure that both the bleader screws are open
if u cant get a pad spreader with a large chanel lock plyers and a peice of cloth carefully forc it in try not to scratch the paint off.
Old May 28, 2005 | 03:08 PM
Turbolover's Avatar
yes to all the above but also pop the top of your fluid resovior and drain out some fluid. put a towel around the resovior.
Old May 28, 2005 | 07:48 PM
value's Avatar
C-clamp ?
Old May 28, 2005 | 07:53 PM
taylor's Avatar
Did you try to push the piston in using the old pad as a lever against the rotor? It worked for me.
MARQ
May 8, 2016 07:52 AM
boost monster
Apr 25, 2014 02:11 PM
MR White
14
Mar 3, 2013 10:21 AM
OzPrince
Jan 23, 2012 10:08 AM
EvoBk
Oct 3, 2007 06:13 AM
