Alky water alcohol injection installation question
Hiheatevo,
I am not an engineer nor one of the person that built the alky kits but let me put it this way, if you install the nozzle on the exit of the intercooler by the time it reaches the Throtle body the temp is going to go up.
Then also you have the BOV disturbing the path and flow of the air flowing from the intercooler to the throtle body.
Ideally you want independent nozzles right at the mouth of each intake manifold tubing. Unfortunately that cost a lot and you have to custom build it. Anywere from 4-8" to the throtle body should work the best for most kits , normally right after the last bent prior to the throtle body .
Carlos
Carlos
DecBro
Feb 17, 2017 07:51 AM
LCS
Feb 24, 2016 01:35 PM
90GSXDan
17
Nov 29, 2008 12:36 PM
EVO8LTW
250
Jan 27, 2006 12:10 PM
