how do you re-finish stock wheels
Old Jun 23, 2005 | 07:37 AM
EVONation's Avatar
Help...... How how how... do you re-finish stock wheels... I want to do it myself please help...
Thanks
Old Jun 23, 2005 | 09:05 AM
GOT EVO's Avatar
wash wheels, lightly sand with 400 grit, rewash and dry, then use duplicolor wheel primer, then duplicolor wheel coating (paint), then duplicolor wheel clear coat
Old Jun 23, 2005 | 09:06 AM
GOT EVO's Avatar
Old Jun 23, 2005 | 09:08 AM
DCSilvrEvo's Avatar
LOOKS JUST LIKE MY RIMS!!!!! SAME STUFF USED from Advance Auto. WONT EVEN COST U 20BUCKS!
Old Jun 23, 2005 | 09:16 AM
GOT EVO's Avatar
what youll want to get 2 cans primer, 2 cans paint, 1 can clear youll have more than enough
Old Jun 23, 2005 | 09:18 AM
GOT EVO's Avatar
ive done 2 sets of Evo wheels one gun metal one bronze. i plan to do my auto-x set gold when i find the right color. Im looking for the gold thats on ADVAN wheels
Old Jun 23, 2005 | 09:27 AM
ovenmit331's Avatar
question... is this pretty easy to do with the tires still mounted?
and anyone have a picture of the stock wheels painted gunmetal?
Old Jun 23, 2005 | 09:36 AM
Regnout's Avatar
Sounds easy enough. How many coats of each, primer, paint and clear coat?
Old Jun 23, 2005 | 10:42 AM
grcygetr's Avatar
I'm interested in the process to. I plan on painting mine black. Any details would be appreciated!
Old Jun 23, 2005 | 07:13 PM
GOT EVO's Avatar
the trick is to use a deck of cards stuck between the bead of the rim and tire then newspaper elseware.
my wheels are gun metal
as for coats i put about 2 or 3 coats of primer or kept rotating wheels till the 2 cans were gone. then about 3 coats of paint or till i was happy with the finish. 1 coat of clear. if you want the color to stay the same after its paint only you have to spray the clear very lightly. the more clear the more the color will change. my wheels turned out much darker after i put the clear on.
Attached Thumbnails how do you re-finish stock wheels-my-evo-010.jpg   how do you re-finish stock wheels-my-evo-011.jpg
Old Jun 23, 2005 | 09:30 PM
j8's Avatar
j8
I did mine about a year ago. Went with flat black. Here is the process I came up with.
1. Deep clean wheels use household dishwashing soap. Remove all particles. The cleaner the better.
2. Sand wheels with 1000 grit sand paper. Make sure you get all the cracks. Take your time, the better you sand the better the results.
3. Re-wash wheel.
4. Dry wheels and then use a tach cloth to remove all particles.
5. Prep your wheels. I used simple masking tape to mask off the tires. Make sure you get it all the way around the exposed part of the tire and down into the crack where the wheel meets the tire.
6. Spray primer coat.
7. Spray first coat of paint. I used high heat flat black spray paint. Yes, the same stuff you use for your BBQ.
8. Let dry for 30 min or what ever is recommended between coats on your can.
9. Spray second coat of paint.
I did not clear coat the rims. I was looking for a true flat black look with no gloss. If you want to spray clear you should follow the directions on the can. Usually it is one hour after you final coat of paint or 24 hours. Total time for all four wheels should be around 6 hours. Have fun and take your time.
By the way I have a picture in my sig.
Old Jun 23, 2005 | 10:13 PM
grcygetr's Avatar
perfect info...
how bout the mods sticky this in the how-to section?
Thanks again!
Old Jun 24, 2005 | 05:50 AM
Regnout's Avatar
perfect info...
Thanks again!
+1. Thanks also. I will be trying this soon.
Old Jun 24, 2005 | 06:29 AM
GOT EVO's Avatar
your final finish will reflect your prep work so take your time when sanding and get EVERYTHING
another tip lightly cover the tires with soap so if you do get ant overspray on them it will some right off because of the barrier between tire and paint
Old Jun 24, 2005 | 06:38 AM
DCSilvrEvo's Avatar
Or you can use some Tire shine like i did. All the over spray wipes right off with no effort.
