Blitz FATT w/ HKS Harness Install
Old Jun 27, 2005 | 01:47 PM
Robert_K's Avatar
I'm just going to provide links to pics so the thread isn't 20 miles long.
-Tools You'll Need:
-Phillips screw driver
-10mm socket & wrench
-Drill & 1/2" & 3/8" bit
-Extra tie downs
1) Remove the three (3) screw under steering colum. http://gallery.getsideways.net/album...s/DSC00635.jpg
2) Remove the two (2) screws on underdash & remove coin holder. http://gallery.getsideways.net/album...s/DSC00636.jpg
3) Remove the 10mm bolt behind the coin holder. http://gallery.getsideways.net/album...s/DSC00637.jpg
4) Remove the headlight leveling & diming wiring. Let hang. This will help by freeing up some room.
5) Remove and install the wiring harness on steering collum. Make sure you hook up the purple e-brake wire to the harness. http://gallery.getsideways.net/album...s/DSC00639.jpg
6) I tied down the wiring harnes so it doesn't get in the way of the steering wheel. http://gallery.getsideways.net/album...s/DSC00640.jpg
7) Remove the center consol. Remove two (2) screws in the arm rest storage. http://gallery.getsideways.net/album...s/DSC00641.jpg
8) Pull up from behind the arm rest. Should just pop right out. Becare of the I/C spray button wiring. Just detach I/C Spray and place consol to side.
9) Remove the plastic retainer by drivers right foot. Just unscrew w/ phillips screw driver. http://gallery.getsideways.net/album...s/DSC00642.jpg
10) Remove 2nd plastic retainer by driver's right foot. Do this by pushing the center in and pull out. http://gallery.getsideways.net/album...s/DSC00643.jpg
11) Remove cover by passenger's left foot and repeat step ten (10). http://gallery.getsideways.net/album...s/DSC00646.jpg
12) Remove ashtray and remove the screw underneath. Also unscrew the shift knob. http://gallery.getsideways.net/album...s/DSC00645.jpg
13) Remove two (2) screws at base of center consol. http://gallery.getsideways.net/album...s/DSC00647.jpg
14) Lift consol up and back to remove. Unlatch the wiring that is attached. Place to side.
15) I mounted the main timer here: http://gallery.getsideways.net/album...s/DSC00648.jpg
-Just used the double sided tape provided. I did use a cleaner to remove any dirt/oil/grease that might be on the timer and/or the place I mounted it to.
15) I found these two (2) screws, on the passenger side, a perfect place to ground the two (2) black wires. http://gallery.getsideways.net/album...s/DSC00649.jpg
16) I ran the purple E-brake wire along the passenger side. Attach it to the E-brake wiring. http://gallery.getsideways.net/album...s/DSC00650.jpg
-Make sure you have a good conection. If not the timer will not work. This is to prevent someone getting into your car while counting down and driving off. Once the E-brake is released the timer shuts off.
17) Get the front center consol w/ the ashtray and shifter leather. I mounted the timer display behind the shifter. http://gallery.getsideways.net/album...s/DSC00652.jpg
-Once again clean real well. Don't want the timer to fall off becasue you ArmorAll the crap out of your car.
18) I drilled a 1/2" hole on the side to run the display wiring. http://gallery.getsideways.net/album...s/DSC00651.jpg
-You'll need it to be 1/2" so the connection will fit through. The second 3/8" hole is just so a tie down will hold the wire in place.
19) Run the display wire to the main timer consol and connect.
20) Test timer first!!! Don't replace everything till you make sure the timer works! If the timer does not work 1st check the e-brake connection. If that doesn't help check all connections. If that doesn't work, called Blitz.
21) Once everything is working put your car back together and enjoy.
Here is a couple pics of my final product:
Old Jun 28, 2005 | 05:58 AM
Robert_K's Avatar
Edit: I updated the pics. Sorry they weren't posting.
Old Jun 29, 2005 | 11:12 AM
Robert_K's Avatar
Where has eveyone else mounted their timer?
Old Jul 18, 2005 | 02:30 PM
exhaust_note's Avatar
thanks for the right up 2 weeks after i intsalled mine by guessing....
any its nice and i installed mine under the tach
Old Jul 19, 2005 | 05:00 PM
Robert_K's Avatar
Sorry you didn't find it sooner, But glad you enjoyed the write up.
Old Aug 9, 2005 | 11:25 AM
Osiris1012's Avatar
THANK YOU for posting this, im looking into getting the exact same unit and havent been able to find a good write up. Yours looks great with all the pics ect.
Old Aug 9, 2005 | 11:35 AM
Robert_K's Avatar
Thanks for the comments Osiris1012. Its a fairly easy install.
Old Oct 8, 2005 | 11:04 AM
3vil3vo's Avatar
Is the HKS TT harness plug and play with the Blitz TT? Or do you have to cut and solder the two together? Thanks... Oh Blitz makes TT harnesses, why not just use them?
Old Oct 30, 2005 | 06:31 PM
EvoRacer619's Avatar
good info had one of these in my WRX but the back light took a crap might pick one up and give another try
Old Nov 16, 2005 | 06:12 AM
Robert_K's Avatar
The HKS is a plug & play... No cuting or anything. The reason for the HKS harness it I use to have a HKS Type 1 TT. I think they all are the same just a different name.
trinydex
Mar 29, 2007 05:45 PM
Robert_K
44
Sep 12, 2005 05:19 AM
Robert_K
Aug 8, 2005 03:53 PM
