Greddy Boost Gauge Wiring
To help others avoid the pain of trying to figure out how to wire a Greddy boost gauge, I thought I'd share where I found the wires to get it to work.
* Constant Power: Accessory fuse with pigtail, in lower 20 Amp fuse behind compartment on left-hand side of dash
These wires are under the rear console:
* Ignition Power: Red wire
* Lamp Power: Green w/ White stripe wire
* Ground: Black wire
Tips:
* Disconnect the negative battery terminal for the install, you're connecting to constant power
* Check to make sure the gauge powers up and reads 0 turning on the ignition before you button everything up. NOTE: The gauge won't read anything without the sensor plugged in, so you'll need to plug in the sensor to make sure you have the wiring correct
Tips:
