Compression Test How-To
Old Mar 27, 2007 | 06:56 AM
tran03's Avatar
Great writeup. I was about to go do this at a dealership or a shop but now I think I can do it myself.
Thanks a lot. I'll post results by this weekend.
Tony
Old Feb 11, 2008 | 04:20 PM
EvoDan2004's Avatar
ok i did the how to which worked great but here are my results.
1. 170 at 7 cranks 180 at 10 cranks
2. 175 at 7 cranks 180 at 10 cranks
3. 175 at 7 cranks 180 at 10 cranks
4. 180 at 7 cranks 185 at 10 cranks
i did not know how many cranks to allow so i did a reading a 5 7 and 10. 5 was the same at 7 basically..
so to the pro's how is my compression looking???
to do a wet test how much oil do we add?? do we do it when the motor is hot as well??
03 evo8
stock blcok
60k miles
Old Feb 11, 2008 | 04:33 PM
EvoDan2004's Avatar
03 evo8
stock blcok
60k miles
bump
Old Feb 11, 2008 | 04:40 PM
EvoDan2004's Avatar
03 evo8
stock blcok
60k miles
bump
sorry motor is getting cold. dont know if i should do this hot warm cold.
Old Feb 11, 2008 | 05:07 PM
EvoDan2004's Avatar
bump
Old Feb 18, 2008 | 11:15 AM
broddey's Avatar
So if I can't keep my engine running for long, what should the compression be when cold?
Mine read 120 on three cylinders and 115 on the fourth. Any ideas as to whether or not this is normal on a cold engine?
Old Apr 8, 2008 | 12:43 PM
BosanskaTrava's Avatar
bump for last two questions!
Old Apr 8, 2008 | 04:31 PM
aspensvt16's Avatar
I got 177 178 177 180 from passenger to driver side. I let the engine crank over for approximatly 3 seconds. Engine coolant temp was 50 degrees. Does is change if the car was not warmed up before the engine was compression tested? Does the amount or time you let your engine crank over increase the psi.
Old Jun 9, 2008 | 10:33 AM
Inprogress's Avatar
Will I need anything else besides this?
http://www.harborfreight.com/cpi/cta...emnumber=95187
In terms of any connectors?
I know I'll need connectors to remove the old spark plugs, but what about connecting the compression tester into the cylinder?
Old Mar 9, 2009 | 09:45 AM
Redline06's Avatar
Bumping from the dead.. lol
Can this method be applied to other cars as well.. ie. the wife's corolla..lol
Old Mar 24, 2009 | 10:04 AM
Sievers's Avatar
Nice. Does anyone know how to find out your compression ratio? I have no idea.
Old Apr 27, 2009 | 06:01 PM
detroit pistins's Avatar
bump
Old May 19, 2009 | 12:23 AM
guapoholic's Avatar
As a rule, most engines should have 140 to 160 lbs. (in the Evos case High 170) of cranking compression with no more than 10% difference between any of the cylinders.
-Low compression in one cylinder usually indicates a bad exhaust valve.
-Low compression in two adjacent cylinders typically means you have a bad head gasket.
-Low compression in all cylinders would tell you the rings and cylinders are worn and the engine needs to be overhauled.
Old Jun 21, 2009 | 01:55 PM
xRoguex's Avatar
Just picked up my evo - did a test. Car has unknown mods. with 60k on it - i got 179 across the board on 5 cranks.
Sounds odd?
Old Oct 2, 2009 | 04:47 PM
kaj's Avatar
kaj
155/150/155/132
