How do I get under the carpet...
Old Oct 25, 2005 | 10:57 AM
Willie Dynamite's Avatar
...on the passenger side?
Old Oct 25, 2005 | 11:00 AM
Cajun Power's Avatar
What part?
center line all the way forward- remove center console and then you can lift carpet. It is connecteed to the drivers side so you can only move it a bit.
outside edge- remove the sill cover and seat if you need to get to the area by the o2 sensor.
Old Oct 25, 2005 | 11:02 AM
Originally Posted by Cajun Power
What part?
That's is there. Do the sills just pop out?
Old Oct 25, 2005 | 11:03 AM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
sills pop (and screw up near the front) right out in 1 minute and pull the carpet back( can't remember but i think the front of the carpet by the firewall has some plastic big screw things holding it....that might be only on the drivers side though
Old Oct 25, 2005 | 11:06 AM
Thanks guys. I'll give it a try.
Old Oct 25, 2005 | 11:40 AM
Ok, I had to remove the passenger seat but I was able to get to the O2 so it worked out. There was an anchor screw on the passenger side.
