Tube coming off turbo on ic kit
the dump tube or whatever its called coming off the turbo, for the hotside pipes of the ic is there an easy way to get it off ? does anything else besides all other pipes need to come off? please help./
If you have access to a lift, thats the easiet way, otherwise jack the passenger side up, take the splash sheild off, undo the coupler and pull. I had a headache trying to fit new intercooler pipes on, and after 2 different kits, and a bunch of couplers that ive went through im back with the stock pipes and love it. No reason to change intercooler pipping unless you making crazy numbers, if you decide to anyway make sure you have alot of time and patience because its not an easy job.
