MAF to MAP
Old Jan 3, 2006 | 01:35 PM
Kerr's Avatar
Fomer Vendor
MAF to MAP
Ok, Ive tried searching with minimal luck. I will be running the EMS and need to know what I have to do to convet to map.
What sensors will work(meaning AEM's or a GM etc.) and which do I need? So far it seems like I will need the map sensor and and iat sensor. Where do they go and how do you wire them? Can the stock ecu run with the conversion? And anything else that could be informative.
If this has been discussed already, of course point me in the right direction.
Thanks
Matt
Old May 30, 2006 | 11:49 PM
ciclops04's Avatar
ok dude go to buschur racing and look for the ems and they have the sensors you are going to need like the gm boost solenoid, 3.5 map sensor and the iat sensor they sell everything you need to started up and no the stock ecu...cannot run with those mods.
