Rotor Removal Stuck??
Old Jan 10, 2006 | 08:41 AM
nbpal4000's Avatar
thanks for your help guys...
i had no one to stand on the break while i turn the axle nut
so i just put in tire and let the car off the jack stand and used the cars weight againt my torque wrench..
It was PITA job..
if this happens again..im gonna raise hell to the manager of that shop!
it was good thing that i had my evo 7 repair manual(99% same as evo 8)
if anybody wants it just talk to me thru (AIM ID:nbpal3000) or email me at
nbpal3000@msn.com
Old Jan 10, 2006 | 08:51 AM
58177's Avatar
I just got a mallet and just pound that rotor until it got loose. I think it was rusted in so it wouldn't slide out. The front just came right off but the rears were stuck in. I'm not sure what everone is talking about maybe I did it wrong but good luck anyways.
Old Aug 29, 2006 | 03:59 PM
AfireINSIDE's Avatar
The radiator shroud bolt worked perfect!
Back from the dead
Old Aug 26, 2007 | 11:02 AM
4WS Tuning's Avatar
i just want to say this should be a ****ing sticky!!!!!
20 min of struggling!
FORUM IS AWESOME!
Old May 11, 2008 | 01:51 PM
joedr's Avatar
EvoM Moderator
Yeap! This should be a sticky!
Old Jun 16, 2008 | 08:44 AM
Hen5000's Avatar
Yeah i think mine is rusted on, as the bolt trick didn't work. Any idea what i should do next? I tried hammering it out and it didn't work either. I twisted the bolt in some more and ended up breaking some spring cup holder behind the rotor.
Old Jun 21, 2008 | 08:57 AM
tseitz123's Avatar
Seriously, beat the **** out of the rotor with a hammer. Mine took awhile too
Old Jun 22, 2008 | 05:47 PM
Hen5000's Avatar
turns out the parking brake got shifted. after hammering it out had to buy a replacement pin holder and fix the parking brake. I blame my bro in law for pulling my ebrake... haha
Old Mar 22, 2009 | 07:46 AM
9evolution's Avatar
Yep Having the same problem. What a PITA. Jeep with 200000 miles rotors come right off. Evo 25000 miles refuse to come off. Just hit it with wd40 few min going to hit it with a mallet a few times. If not going to try the shroud bolt.
Old Mar 22, 2009 | 02:27 PM
9evolution's Avatar
Thanks. radiator bolt was perfect worked like a charm. zero effort.
Old Mar 22, 2009 | 02:32 PM
FastLearner's Avatar
Please make sure you don't have the e-brake on before you try and remove the rear rotor.
Old Oct 20, 2009 | 12:15 PM
varner88's Avatar
how does the hub itself come off Im trying to put my wheel studs in.. Do I have to remove the ball joints? or does the hub unbolt like the hondas do?Also does the ebrak need to be taking apart?
Old Mar 9, 2010 | 09:00 PM
bahnzii's Avatar
Just to add, I had the same problem tonight changing my rotors...I was like WTF the rotor is frozen/rusted on
Found this thread in a search and the radiator shroud bolt worked like a charm!!
Much better than the 10 min's I spent with a rubber mallet and some WD40
Thanks to everyone who posted suggestions, especially the radiator bolt trick
Old Apr 6, 2010 | 05:29 PM
reconracer's Avatar
yea i rememeber the first time i did a rotor took me a min to figure it out, screwing a bolt in didnt pop into my head right off then again i was 12 helping my dad out
Old Apr 6, 2010 | 05:58 PM
lemmysports2's Avatar
no no no, no hammer! i made that mistake and did more damage then good with my parking brake.
its a drum (we all know this) when it wears out, a lip is formed on the inside which prevents the rotor from sliding off the parking brake shoes.
if you look on the backside of the rotor/ heatsheild youll see an oval shaped rubber gromet, take that out and inside is a wheel you turn to release tension from the parking brake. then the rotor will come off no problem. ill see if i can find a picture, but if you look on the back of the rotor you should be able to figure it out.
"I've never seen a drum brake that didn't have some means to access the self-adjuster. Usually it's an oval-shaped hole near the center of the lower half of the back plate. There's a rubber piece you have to pull out of the hole, and then you stick a screwdriver in there to loosen the adjuster. There will probably also be a little piece holding the star wheel part of the adjuster, so it only turns in one direction. In that case, you need 2 screwdrivers. One to hold the little piece off the star wheel, and the other to turn it the way the piece wouldn't allow it to go.
I really hate drum brakes."- from another thread
