New FMIC, downpipe, cat delete
Old Feb 10, 2006 | 02:47 PM
BaseModelEvo's Avatar
What's up guys?
Well I got my new FMIC, it's a prototype piece a friend of mine is making. He'll have more soon. Dimensions are 28" (end pipe to end pipe) 22" wide, 20" tall, 3.5" deep. Beautiful polished finish. Bar and plate. 1200 CFM @ 1.2psi drop. Roughly 80% more efficient than stock. Had a pipe kit, but fitment sucked, so I sent it back and ordered HKS, which is why you'll see stock pipes on the FMIC. I'll post the new pics when I get the kit installed!
Downpipe and cat delete are made by Tsudo. Cat delete is CLEAN and threw a code once but I got into boost early then let out and the car tried to stall, so I consider it my fault. Both pices work AWESOME. Power is AMAZING, and it sounds PISSED under full throttle.
PERFORMANCE: Holding nearly 2lbs of peak boost. Freeway pulls are getting exciting, finally. I may be in the neighborhood of 400 crank power with the hard pipes, electric water pump, and WORKS computer installed. I'll get some dynos soon. Take care all. Hope all is good with all of you! Check out the website for pics of IC and install!
www.garagedonline.com <---- pics there. it's my shop site.
-Woody
Old Feb 11, 2006 | 03:33 PM
ford381stroker's Avatar
nice. i have an RS and I am looking to mod mine but waiting to see what combos others are using and what works best
