Installing control arm bushings
Old Apr 6, 2006 | 11:51 AM
sponge bob's Avatar
But I need a rear suspension diagram and torque specs to finish the job. I need a diagram including torque specs of the rear suspension of an EVO VIII. Can some please post it here or email me? I have tried searching for it but could not find a diagram with torque specs, it’s the torques specs that I need. I will order my service manual CD today but I really need this diagram soon.
Thanks
Old Apr 6, 2006 | 12:04 PM
justchil's Avatar
GENERAL SPECIFICATIONS
COIL SPRING
ITEM SPECIFICATION
Assist link
Assist link mounting nut 93 ± 15 N⋅m (69 ± 11 ft-lb)
Assist link to knuckle nut 81 ± 6 N⋅m (60 ± 4 ft-lb)
Lower arm assembly
Lower arm assembly to crossmember nut 93 ± 15 N⋅m (69 ± 11 ft-lb)
Lower arm assembly to knuckle nut 88 ± 10 N⋅m (65 ± 7 ft-lb)
Lower arm assembly to shock absorber nut 88 ± 10 N⋅m (65 ± 7 ft-lb)
Rear suspension assembly
Crossmember mounting bolt 88 ± 5 N⋅m (65 ± 3 ft-lb)
Differential support assembly mounting nut 120 ± 10 N⋅m (89 ± 6 ft-lb)
Propeller shaft mounting nut 32 ± 2 N⋅m (24 ± 1 ft-lb)
Rear brake caliper mounting bolt 54 ± 5 N⋅m (40 ± 4 ft-lb)
Shock absorber assembly
Shock absorber assembly to body nut 44 ± 5 N⋅m (33 ± 3 ft-lb)
Shock absorber self-locking nut (Coil spring nut) 25 ± 5 N⋅m (19 ± 3 ft-lb)
Stabilizer bar
Stabilizer bar link mounting nut 39 ± 5 N⋅m (29 ± 3 ft-lb)
Stabilizer bracket bolt 24 ± 4 N⋅m (18 ± 3 ft-lb)
Stabilizer bracket to crossmember bolt 39 ± 5 N⋅m (29 ± 3 ft-lb)
Trailing arm assembly
Trailing arm assembly to knuckle nut 81 ± 6 N⋅m (60 ± 4 ft-lb)
Trailing arm assembly to body bolt 147 ± 9 N⋅m (109 ± 6 ft-lb)
Upper arm assembly
Upper arm assembly mounting bolt (front) 49 ± 5 N⋅m (36 ± 4 ft-lb)
Upper arm assembly mounting bolt (rear) 64 ± 4 N⋅m (47 ± 3 ft-lb)
Upper arm assembly to knuckle nut 81 ± 6 N⋅m (60 ± 4 ft-lb)
ITEM SPECIFICATION
Wire diameter mm (in) 12 (0.5)
Average diameter mm (in) 88 (3.5)
Free length mm (in) 287 (11.03)
SPECIFICATIONS
TSB Revision
34-30 REAR SUSPENSION
SERVICE SPECIFICATIONS M1341000300357
ITEM STANDARD VALUE
Toe-in mm (in) 3 ± 2 (0.12 ± 0.07)
Camber −1°00’ ± 30’ (Difference between
right and left within 30’)
Thrust angle 0°00’ ± 0°09’
Upper arm ball joint turning torque N⋅m (in-lb) 0.5 − 2.5 (4.4 − 22)
Trailing arm ball joint turning torque N⋅m (in-lb) 0.5 − 2.5 (4.4 − 22)
Assist link ball joint turning torque N⋅m (in-lb) 0.5 − 2.5 (4.4 − 22)
Assist link slide bushing turning torque N⋅m (in-lb) 0.5 − 2.0 (4.4 − 17)
Lower arm pillow ball bushing turning N⋅m (in-lb) 0.5 − 3.0 (4.4 − 26)
Stabilizer bar link ball joint turning torque N⋅m (in-lb) 1.7 − 3.1 (15 − 27)
This may be hard to read. Here is the rear suspension section out of the manual:
http://www.justchil.net/dl/evo_rear_suspension.pdf
Old Apr 6, 2006 | 12:27 PM
sponge bob's Avatar
Thanks, I owe you one!
Bob
Old Apr 6, 2006 | 06:29 PM
justchil's Avatar
No problem.. let us know how it goes
I plan on getting these one of these days...
Tobra
Lancer Tranny/Drivetrain Tech
Jun 3, 2017 08:17 PM
RogueSTi
19
Mar 14, 2009 10:26 AM
[C-4]PUMA
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jan 25, 2007 09:43 PM
SALEVO
AEM EMS
May 29, 2006 09:30 PM
mcbrown35
Lancer Engine Tech
26
Feb 23, 2005 01:51 PM
