Greddy TT Grounding Question
Old Apr 25, 2006 | 09:29 AM
Jixxer's Avatar
I have a Greddy Turbo Timer with the easy install harness (also from Greddy).
I've taken the top and bottom plastic covers off the steering column, and I've hooked up up the harness. The only thing I have left to do (other than the parking brake/speed sensor stuff that can wait) is to ground everything using the long ground wire. The only issue is I don't know where to ground it out to.
There is absolutely zero room under the dash for me to work with ... I can't even get both my arms into the space. Unless I start pulling apart more of the dash I have no idea what to ground the TT to. I've seen other pages suggesting a bolt by the radio, but I'm not sure how to get to this. Should I remove the radio? Or should I start pulling apart the dash to make more room?
Old Apr 26, 2006 | 06:46 AM
Jixxer's Avatar
I took out the radio and grounded the TT to the frame behind.
Fired it up last night and it works fine.
