hey guys I've just started doing research on which intake would work best on the VIII. What would you recommend because I heard that cold air intakes don't necessarily work the best with turbos. A lot of people have that hks yellow spongelike shortram. Or does the shortram with the heatshield work better. I would assume that it works better than just a drop in K&N...
I'm also interested in an answer to this question. I recently purchased the Injen intake with the IC pipes and I've heard the intake should be stock??
Quote:
Your assumtion is wrong stick with the stock air box and your drop in.
need to do a little more research...
http://www.mkiv.com/techarticles/filters_test/2/
stock air box + k&n = good times
Now I have the RMR with K&N, but I am tuned for it. But it is a good unit. As far as totally stock (untuned) Id stick to the drop-in.
