Help:
Old Aug 23, 2006 | 06:39 PM
BigEd925's Avatar
Help: Front bumper removal
I am taking off my front bumper for my HID retrofit on friday and ran into some issues. I striped two plastic fasteners and was wondering if anyone had any suggestions on how to remove them and where to buy them when its time for my bumper to be put back on.
see pic.
Old Aug 23, 2006 | 06:45 PM
BretTheJet26's Avatar
bah, those things are a ***** and there are like 20 million of them...
when i had that problem, i took out some of the surrounding clips and kind of pulled the splash guard a little while unscrewing, fiddle around w/it you'll figure it out
Old Aug 24, 2006 | 06:29 AM
RyanM's Avatar
You can drill the center out
Old Aug 24, 2006 | 06:30 AM
RyanM's Avatar
http://www.lancershop.com/customer/s...substring=popp
Old Sep 10, 2006 | 01:02 PM
JohnEB's Avatar
I have this happen all the time.... just pinch both sides with pliers.
Old Sep 11, 2006 | 12:30 PM
RRRS's Avatar
i never had problems getting those clips out. the trick is to turn the screw w/o using pressure, i use a long phillips bit and not a driver to do this. hold on to the base of the clip while turning the screw out, when u have enough threads out u can use your fingers to unscrew it out more, and then just wiggle it out.
