Cleaning the throttle body
Use sea foam. You can either apply it through the vacuum port or spray the throttle body. I used it on many of my car i had owned in the past.
This might give you some idea. http://honda-tech.com/zerothread?id=1502112
i use Throttle carb cleaner...definetly made a difference in idle...TB is real sensitive as far as build up...
sea foam is awesome stuff too...clean the motor and fuel system...
draceteam
13
Feb 19, 2003 02:48 AM
