Evo VII standard fuelpump size (diameter and length)
Hi all,
anyone know the dimension of the standard EVO VII's fuelpump ?
I am trying to replace it and found the denso one with: 127mm tip to tip, 100mm fuelpump's body length, 145mm with the filter and the pump diameter is 51mm...
will this denso above direct replace the standard pump.??
Thanks,
Guntur
Thanks,
Guntur
