VEI Triple-Gauge Install - boost, AFR, oil pressure
Old Oct 20, 2006 | 05:41 PM
Turbo-Ron's Avatar
OK - just got done installing VEI systems gauges on the CRD Evo IX!
These gauges are super accurate!
Check it out: http://www.teamcrd.com/projects/evotriple.html
Old Oct 20, 2006 | 05:52 PM
BigBallin's Avatar
nice write up
Old Oct 20, 2006 | 05:53 PM
BigBallin's Avatar
ps the online store isnt working
Old Oct 21, 2006 | 05:46 PM
Turbo-Ron's Avatar
Thank you. ... Yes, the database is under repair, you can call CRD directly if interested in getting a set of these gauges.
Old Oct 21, 2006 | 06:38 PM
BigBallin's Avatar
what size are they? i would just want the gauges and not the mount
Old Oct 23, 2006 | 02:27 PM
Turbo-Ron's Avatar
they are 52 mm, and programable for brightness, auto dim at night to match your console, the response rate can be sped up or slowed. dual bar graph and numerical display can also be easily adjusted by user. You can set alarm levels as well.
... and, they look even better in person.
Old Jan 12, 2007 | 10:54 AM
fostytou's Avatar
EvoM Community Team
They look very nice!
The only thing I might change is tapping the dimmer switch or headlight switch inside the car instead of directly on the headlights, otherwise Great writeup!
trinydex
Jun 30, 2014 02:26 AM
blkmkIII
May 9, 2010 11:54 AM
EvolNinja
Apr 20, 2008 12:35 PM
mscorei
Nov 26, 2007 09:24 AM
savior1974
Nov 7, 2007 05:26 AM
