How to Install Power Locks on a RS
Old Jan 22, 2007 | 12:21 AM
RoadSpike's Avatar
This is a labor intensive process that requires the drilling of your rear doors so be warned...
Tools:
- Screwdrivers both kinds
- 12mm wrench
- 10mm socket and ratchet
- Drill
- Drill bits
- Bundle O zipties!
- Patience like a saint
The parts:
I used commando alarms system with 4 door actuators, control unit, alarm, siren, and trunk popper for the grand total of 120 bucks. Pretty much any 4 door actuator kit is going to be exactly the same and install the same way.
Picture of the actuators:
To begin pop the panels off the doors:
You'll need something to pry the cover tabs off the inside handle and latch. Be warned that the cover on the door handle likes to fly off. Also roll the windows down it helps when removing the panel in the final step.
Remove the screws on the outside and inside corners of the door with your Phillips screwdriver. remove the screws in the latch and inside the door handle. There are tabs on the cover for the latch so just lightly prying on the inside above the locking switch will release the cover.
Next is to remove the window roller its locked into place with a clip my favorite method to release the handle from the lever is to push the screwdriver and push the clip upward, the handle should pull off easily after that.
Pry the door off by gripping underneath it and yanking firmly the pop tabs will pop off and your panel will then be free. just slip the end piece off the window and you should be able to slide the panel free.
Remove the metal bracket for the door handle and peel off the plastic cover.
Step 2 Run the wires:
The front doors are easy on the RS. Take a window handle and roll the window all the way up then reach into the door frame near the inside corner and pop out the rubber gromet for door by pulling it inward. You can then push it back out slice the rubber inside part (don't get agressive and cut your speaker wires) then push the wires you need for the actuators into the rubber via the tube inside the cabin.
I used a 5 wire setup so when the doors are locked or unlocked they all lock or unlock. I used 2 wire actuators in the back. When running your wires make sure to zip tie them to the front of the door frame so they wont be hit by the window as it comes down. Pulling the clip off one of the window handles for testing is nice for this purpose. Make sure you remember to push the rubber grommet back into place when your done pulling wires through it.
The rear doors require drilling, so with that in mind your going to want to use some flex tubing (i used 3/8") and need a drill and appropriate drill bits. I choose to set a mark only a couple inches underneath the latch to aviod the triple plating below and the seat belts and respective wiring.
I'd drill the doors first then the B pillar mark your B pillar so your holes line up. When your done take the doors off, if your good at adjusting doors you wont need to mark the hinge locations otherwise mark them with a grease pen.
Step 3 (Intall the actuators and brackets):
Ironically the rear actuators are much easier to install than the front ones. The reason is the front door uses a cable system instead of a solid bar to move the locking mechanism. This requires you to carefully cut away at part of the cable, then zip tie the cable housing upward to provide adaquate tension so the locking mechanism will function normally. Here's a picture of another install with the cut away.
I used a drill and drill screws (3/4") to put the bracket on them used the provided bar and screws to attach the actuator to the bracket. Premeasure the distance to the cut away by pulling the actuator out fully when installing. Some man handling of the bracket and bending it towards you will help you prevent the bar from binding on the cable too much. When your done just connect your wires zip tie them and check that your window will still close properly.
The rear door is completely different in that it uses a solid bar. So while mounting is the same the install for the actuator is simplified in that you don't risk destroying your locking wire by a miscut.
Testing:
Its a good thing to test these units before buttoning everything back together. First test them with a remote power source like a spare battery. I have a battery jump starter so i used that in my testing. First make sure the units open and close fully without assistance. Next put the door panel mostly on and test again to be sure the unit isn't binding on the insulation or the foam pieces (which i tossed). On the rear for example a plastic peg got in the way so i just chopped it down and presto it worked perfect.
I'll leave it to you to decide where to mount the control module and supply the power source.
Attached Thumbnails How to Install Power Locks on a RS-screwdriver.jpg   How to Install Power Locks on a RS-window-handle.jpg   How to Install Power Locks on a RS-b-pillar.jpg   How to Install Power Locks on a RS-pwrlock1.jpg   How to Install Power Locks on a RS-pwrlock2.jpg
Old Jan 22, 2007 | 12:22 AM
RoadSpike's Avatar
Some more pictures
Attached Thumbnails How to Install Power Locks on a RS-rear-door.jpg   How to Install Power Locks on a RS-wires.jpg
Old May 6, 2007 | 09:47 AM
vmrevo9's Avatar
Veteran: Air Force
good write up but do you know that the RS comes with the actuators already installed? I'm in the process of installing an alarm and i had bought the actuator kit and by looking at the door lock i found out that the locking system has an actuator built in.
Old Jun 8, 2007 | 08:46 AM
Dosagex's Avatar
LOL damn RS
Old Aug 25, 2007 | 08:55 PM
Dubius's Avatar
Why would you take the doors off at the end of step 2?
Old Aug 31, 2007 | 08:53 PM
RoadSpike's Avatar
Damn i need to subscribe to my own thread..
Anyways I took the doors off becuase i needed to drill a hole into the b pillar where i could push the wires into. There aren't any wires installed to the rear doors. If you plan on having rear locks its kinda necessary.
As far as actuators already installed i had no idea.. They definitely aren't in the back so i guess i would have to do something anyways. Back doors have no wires at all installed.
Old Jan 16, 2008 | 12:29 PM
eclipsegsx012's Avatar
Just curious Could you put regular Evo 8 or 9 GSR door pannel with power lock's and power window on the RS?
Old Jan 17, 2008 | 09:42 AM
RoadSpike's Avatar
You could easily on the front doors because the wiring is just sitting around there. However there isn't any wiring in the rear doors so your going to have to get inventive to get any wiring in there such as drilling.
There are additional steps rather then just bolting the doors on if I can remember them all correctly. I remember in some thread about this early on that the doors required a relay module to function properly with the stock equipment. A search for that information probably can be found.
Old Jan 17, 2008 | 02:21 PM
Front door was all i needed anyways!!! Thanks for quick response!
Old Feb 7, 2008 | 09:53 PM
rodman's Avatar
So what did you have to do to get power locks working on the IX RS? Just a keyless entery system without actuator kit?
Old Aug 16, 2008 | 12:48 PM
Juan Martinez's Avatar
I did a swap on a 98 Eclipse, you need one relay that went behind the radio, one that went under the dash on the fuse panel. All I had to do was take the old manual actuator out and put in the new one. The door already had the wiring to plug in the new harness to the power windows and locks. I'm not sure what they do for 4 doors.
Old Feb 25, 2009 | 10:05 PM
X91EVO's Avatar
Registered User
if anybody with an rs would want to swap their non power window and non power lock components with my power window and power lock components
PM ME!!
I would love to save some weight
Old Nov 12, 2009 | 07:52 PM
speedfreak24's Avatar
i want to do this sooo bad but i dont know man looks scary haha i wish i had power locks...stupid rs. the only thing i wish the rs had.
Old Mar 28, 2011 | 12:05 AM
umopp's Avatar
Sorry for the necro-bump but has anyone done a swap with the oem components from another evo? I currently have all 4 door panels, their respective switches, window motors for all 4 doors, and the wiring harness. All I need to buy now is the power lock mechanisms, actuators, or whatever you call them. So here are my questions. Do I just straight up take out the manual components from my RS and swap the power stuff in or is their more to it than that? I'm not an electrical expert but what was meant when the person posting a few posts up said that they used several relays? Would I need that? Also, would the OEM door panels and switches I have be compatible if I bought an after market door actuator kit? Thanks for the help guys.
Old Mar 28, 2011 | 05:24 AM
gsrboi80's Avatar
Yes I did power door locks in exs RS by putting factory PDL actuators in the doors and ran wires to them from the after market alarm. Was quite simple that way
