Painting Brembos how to
Old Apr 19, 2009 | 06:20 PM
  #166
huevosrancheros's Avatar
I'm pulling mine off to sandblast them. This does look like a nice method. I'm almost tempted to go ahead and pull this off.
Old Apr 19, 2009 | 06:23 PM
  #167
Originally Posted by Redlimit835
caliper off car>>>>2 bolts (i believe aprox 17mm) and one line (12-14mm) hemostat >> free caliper..... and the rotor is as easy as a good thud with a hammer.
thing is if you remove the line you have to bleed your brakes..... and as i found out the hard way alunimum calipers and steel bleeders oxidize together and in no way shape or form like to be loosened or removed... almost had to buy a new caliper when i did this.....had one break off in the caliper too....... was a nightmare with some good old PB blaster and a little heat... the part that worries me most is that my car only had 50k on it.......
neglecting that fact that I "should" bleed my brakes more often.
anyone else have this probem..
later
DJ
its a 19mm socket and they'll pop right off.
Old Apr 25, 2009 | 07:42 PM
  #168
etuhs's Avatar
Nice job, this helped me alot.
Thanks
Old Apr 29, 2009 | 02:29 AM
  #169
guapoholic's Avatar
Anyone here use anything higher than 400 grit when sanding? I want the surface to be very smooth before painting it.
Old May 28, 2009 | 12:29 AM
  #170
eagle claw's Avatar
I like the silver.
Old May 28, 2009 | 01:02 AM
  #171
xRoguex's Avatar
http://cgi.ebay.com/ebaymotors/MUSTA...ht_1473wt_1375
will NOT chip, peal, discolor, messup, ****up, you name it... tested 10,000 miles on an s2000. flawless to this day
Old May 28, 2009 | 04:18 PM
  #172
XracerS13's Avatar
He speaks the truth. Good stuff. Time consuming to apply but turns out nice.
Old May 28, 2009 | 06:14 PM
  #173
xRoguex's Avatar
yeah - left out that part. prep for it sucks but damn guys -- they are perfect after.
Old Jun 14, 2009 | 01:44 AM
  #174
Dlove316's Avatar
Thanks for the write up. Nice to know what to do when my calipers starts to fade
Old Jun 17, 2009 | 10:41 PM
  #175
R/TErnie's Avatar
you want to finish with at least 600. 400 will leave sand scratches
Old Jun 18, 2009 | 02:51 PM
  #176
kaansahbaz's Avatar
nice 1 , i ll do them soon maybe in 2 weeks
Old Jun 28, 2009 | 06:01 PM
  #177
BEISSEN's Avatar
I have just finished mine Almost. I messed up and took them off the car and Im fixing my mistake"Brake Fluid & Brake Cleaner" It was not 100% Dry and cured yet..But I did the Four step ProcessAfter cleaning and stripping.
Step 1.
Clean
Step 2
Strip "Tal-Strip"-Sand & Wipe With Alcohol
Step 4
Primer "Engine Enamel Grey"500F
Dupli-Color Red Caliper Paint "Rattle Can"500F
Apply Decals "XenonMods.com" 10.99 Shipped all 4 corners with extras.
Engine Enamel Clear 500F
I will soon post some pics.
Old Jul 17, 2009 | 12:29 AM
  #178
hinkle0856's Avatar
Just started mine this week, spent the last couple days dremeling all the clear off. Its a pain in the A$$ but sanding is way worse. Will post pics when done.
Old Aug 9, 2009 | 06:33 PM
  #179
Thoe99's Avatar
How much sanding do you do? Are you supposed to sand all the original red paint off? or just the original clearcoat?
Old Aug 9, 2009 | 09:17 PM
  #180
BEISSEN's Avatar
I Used Tal-Strip from Avanced auto to get it done and just sanded what was left and then used fine sand paper to get a nice surface and then did my steps.I also used alcohol afterwards to clean reidue off.
