Stock Exhaust vs Modfied Apexi WS2
Vehicle: 2006 Evo IX
Stock Exhaust vs. Modified Apexi WS2
Stock Exhaust
-stock dp
-stock catalytic converter
-stock catback
Modified Apexi WS2
-stock dp
-RRE Rally cat
-modified WS2 midpipe: RRE 3x24 SS Resonator, 3" SS piping, RRE SS o2 bung, RRE SS 3" flange
-unmodified Apexi WS2 axle back
The following aural tests were with a Radio Shack Sound Level Meter (33-2055). Weighting A tests db ranging from 500hz-10000hz *human ear range. Weighting C test db ranging from 30hz-20000hz.
Stock Exhaust:
Idle:
-Weighting A:
3ft away from tip: 81db
10ft away from tip: 68db
-Weighting C:
3ft away from tip: 100db
10ft away from tip: 87db
3K:
-Weighting A:
3ft away from tip: 83db
10ft away from tip: 75db
-Weighting C:
3ft away from tip: 94db
10ft away from tip: 85db
5K:
-Weighting A:
3ft away from tip: 87db **fluke?
-Weighting C:
3ft away from tip: 91db
Modified WS2:
Idle:
-Weighting A:
3ft away from tip: 80db
10ft away from tip: 71db
-Weighting C:
3ft away from tip: 98db
10ft away from tip: 88db
3K:
-Weighting A:
3ft away from tip: 86db
10ft away from tip: 79db
-Weighting C:
10ft away from tip: 91db
5K:
-Weighting A:
10ft away from tip: 84db
-Weighting C:
10ft away from tip: 86db
*****movie clips to come
*****70mph cruise and WOT test results to come
Apexi WS2 midpipe
Stock Cat vs RRE Rally Cat
Stock Cat Weight
RRE Cat Weight
Modified WS2 Midpipe (top) vs Unmodified WS2 Midpipe (bottom) *less 3" portion
Finished Product
Stock Exhaust
-stock dp
-stock catback
Modified Apexi WS2
-stock dp
-RRE Rally cat
Stock Exhaust:
Idle:
-Weighting A:
-Weighting C:
3K:
-Weighting A:
-Weighting C:
5K:
-Weighting A:
-Weighting C:
Modified WS2:
Idle:
-Weighting A:
-Weighting C:
3K:
-Weighting A:
-Weighting C:
5K:
-Weighting A:
-Weighting C:
Apexi WS2 midpipe
Stock Cat Weight
RRE Cat Weight
Finished Product
Excellent results if you want a quiet exhaust!
I have the WS2 , Apexi GT Downpipe and Works 3"HFC that I will be installing soon.
However, I noticed that the midpipe inlet for the WS2 is made for 2.5"(stock) cat.
Did you fabricate the midpipe yourself ? I am looking/ considering cut and weld
a 3" flange for the midpipe inlet.
Please let me know if you consider selling the midpipe. Thank you.
Rexpeed
Lancer Ralliart Vendor Classifieds
16
Dec 14, 2009 12:13 AM
WheelDude.com
May 21, 2007 11:34 AM
