What wire did I tap into?
Old Aug 9, 2007 | 11:46 PM
CasperGSR99's Avatar
So installing my boost gauge today I tapped into the large gauge white wire under the kick panel. i understand this is 12v constant? its the largest gauge under there
and for the other ign 12v switched i tapped into a YELLOW with GREEN STRIPING also under the kick panel.
What wire is this? my srs light is now on and i need to know if this wire caused it.
Old Aug 12, 2007 | 08:22 PM
urslo4n8's Avatar
i cant say for sure but i tapped into the dimmer switch wires for the constant 12v feed and it works fine
