remove silver ring from steering wheel?
Old Aug 10, 2007 | 04:53 AM
Rexpeed's Avatar
Anyone know how to remove the silver ring around the center horn button?
Thanks
Old Aug 10, 2007 | 05:16 AM
whoang40's Avatar
you try a heat gun or hair dryer? I'm not sure, if it's not bolted it's probably glued on.
Old Aug 10, 2007 | 05:20 AM
turboDan's Avatar
It has 3 clips 120 degrees apart that hold it on,do NOT use a heat gun.BTW,take air bag out 1st and it makes it alot easier to come out.Be careful not to break any of the 3 clips that hold it on,as soon as you get one to release the ring can pretty much come out without depressing the other 2
Old Aug 10, 2007 | 05:24 AM
Rexpeed's Avatar
is there a "how to" on removing the air bag? Where are the 3 clips located at...I would guess you have to take out the air bag to access it?
Thanks!
Old Aug 10, 2007 | 05:26 AM
whoang40's Avatar
yeah sorry bout the heat gun. probably not a good idea with the airbag there!
Old Aug 10, 2007 | 05:43 AM
turboDan's Avatar
Location of retaining clips is 2 o'clock 6 o'clock and 10 o'clock positions.
If you pop off the access cover on back side of steering wheel just below where you have your ARROW you will be able to see the 6 o'clock position clip with a flashlight and mirror.Hope this helps. BTW,be careful as the clips are actually part of the ring and are also made of plastic.
Old Aug 10, 2007 | 05:48 AM
Rexpeed's Avatar
Will go and take a look at it later
Thanks
Old Aug 10, 2007 | 05:51 AM
kmcconn9's Avatar
hmm, a cf steering wheel ring maybe derek
Old Aug 10, 2007 | 06:31 AM
Rexpeed's Avatar
maybe
RU EVO
Jun 24, 2012 03:33 PM
RU EVO
Jul 17, 2011 01:41 PM
m4tt VIII
17
Nov 16, 2010 07:13 AM
icantdrive75
12
Jul 11, 2010 02:49 PM
EvoKnievo
Apr 30, 2010 01:46 PM
