So do you need to bleed the clutch when you flush the brake fluid??
Hi guys,
I have been reading alot of your how to's and am having a bit of problem working out if the evo needs the clutch bled when you do a brake fluid flush, that is changing from regular dot 4 brake fluid to a castrol srf fluid??
