Throttle cable relocation question.
Old Oct 24, 2007 | 08:36 AM
SUBE KLR's Avatar
Question Throttle cable relocation question.
How does one relocate the stock throttle cable so it does not go over the top of the valve cover? Do you need to replace the throttle body to an after market?
Thanks for the help!
Old Oct 24, 2007 | 11:03 AM
tookinkee's Avatar
pm me...i have pics..did it very clean and still looks factory...no issues...did mine a little different then most do on here..
Old Oct 24, 2007 | 11:06 AM
mifesto's Avatar
hmmm i did mine and came out successfully and pedal feel is unaffected... tookinkee can u get me pics of how u did it? made me curious
Old Oct 24, 2007 | 11:10 AM
bigric09's Avatar
yes please post pics if you did something different. I just moved mine to behind the intake mani and mounted it to the firewall behind the a/c..... looks clean and feels stock
Old Oct 24, 2007 | 11:26 AM
Smike's Avatar
Image for you:
Used the cable holder that orig. holds the cable at the front of the valve cover. Moved that back to the ACD solenoid and mounted it there. Reattached cable - done.
Old Oct 24, 2007 | 11:27 AM
True_Story's Avatar
post pics!!!!
Old Oct 24, 2007 | 11:51 AM
SUBE KLR's Avatar
thanks for the help. If you have any more pics, please post them. Maybe a close up of where you connect the bracket from the front of the valve cover. Thanks!
Old Oct 24, 2007 | 11:55 AM
dan628's Avatar
Its easy to do, you just gotta flip it under the strut bar.
bigric09's Avatar
does this help ? kind of a bad angle
Old Oct 24, 2007 | 11:57 AM
Blue Evo 8's Avatar
I did this mod before and the EVO guys from my local EVO forum advised me to put it back to the stock location.
Reason: The positioning of the cable may cause the line to bind or something.....
I dont know....
can anyone else chime in ?
Old Oct 24, 2007 | 11:58 AM
bigric09's Avatar
mine has never... knock on wood.... and its been like that for over a year now.
you arent crimping the line, you are simply moving it to the back.... it literally took me 10 minutes if that
Old Oct 24, 2007 | 12:06 PM
Smike's Avatar
You can see in my picture (sorta) how I mounted the cable holder to the firewall where the ACD solenoid hooks up. And also the 2 zipties on my strut bar are to hold the cable right there. I though about binding or rubbing so I just when ahead and ziptied them to be sure Id have no problems.
Old Oct 24, 2007 | 12:08 PM
bigric09's Avatar
i did as well, just ran them lower than you i guess... mine sits under the catch can i have there and i have ziptied to the lines (i think brake) that are back there.
Here might be a better pic
Old Oct 24, 2007 | 12:47 PM
hksevoix's Avatar
here is mine:
Old Oct 25, 2007 | 08:16 AM
SUBE KLR's Avatar
This last pic looks like another differant way of routing the cable. Thanks for the pic. I'll try both ways and see which one I like and how it feels. Thanks again for ALL the help guys!
Anymore pics out there from anyone elses mod?
