Any How-to for Head removal?
Old Apr 8, 2008 | 08:33 AM
EvoFlash's Avatar
Title says it all.
Old Apr 9, 2008 | 02:12 PM
EvoKnievo's Avatar
check for a how to about head gasket install.
or get a service manual.
you could also use the correct head stud install method ( where you remove the head to install a new gasket)
cliff notes:
zip tie cam gears to timing belt
remove gears
pull studs out
seperate head.....
Old Apr 9, 2008 | 02:17 PM
Wicked E's Avatar
Make a guillotine and pull the string yourself...
In all seriousness, should just be a matter of unbolting that pita bracket on the back of the block that bolts to the intake manifold and un-doing the head studs...
Old Apr 9, 2008 | 02:23 PM
Dapper Dan's Avatar
I hate that damn bracket, ive prolly pulled like 20 heads and its still the biggest PITA lol
Old Aug 19, 2009 | 11:29 AM
supeazn's Avatar
i totally agree with dan that bracket was pita. wonder if it really is needed. i'm thinking leaving it on the intake manifold but not bolting it to the block.
