How to remove a defective O2 sensor, including wiring?
Old Jun 9, 2008 | 06:07 PM
hytek369's Avatar
How would one replace a bad O2 sensor? I stripped mine pretty badly. I was going to remove it all together and replace with a new one. Anyone have experience with this?
Old Jun 9, 2008 | 08:36 PM
Criddlen's Avatar
You can go the checker auto parts(or any other car parts store) and buy an o2 socket. Then buy a new one without the harness (u can buy it with or without the harness) and wire it yourself. It is pretty easy. If it is the front o2 you might have to take out the o2 housing to take out the sensor..
Old Jun 10, 2008 | 07:44 AM
hytek369's Avatar
its the rear one connected to the cat
how do you wire it? i heard the wiring comes from under the passenger seat carpet. from there, where does it connect to? the ecu?
Old Jun 10, 2008 | 07:53 AM
lexat20's Avatar
If you remove the shotgun seat and center console it makes things much easier. And using the o2 socket will make life easier as well. The o2 sensor at the cat has a plug about a foot from the sensor.
Old Jun 10, 2008 | 08:29 AM
hytek369's Avatar
so i don't need to take out the center console if i can just remove the o2 sensor from the bottom of the car (by unplugging the plug a foot from the sensor)?
Old Jun 10, 2008 | 08:44 AM
lexat20's Avatar
I believe the plug is under the seat, I cant remember 100% though
Old Jun 13, 2008 | 06:56 PM
hytek369's Avatar
has any one solder a new o2 sensor on as a replacement? i am referring to the one in the cat.
