Help with installing boost gauge
Help guys i followed the instruction posted above but I cant get my gauge to work this is what i have done so far, gave the gauge power and routed a vacumm line thru the back end of the glove compartment and cut the vacumm line shown in the pictures....what im i missing? i have been doing this for 2 hrs ...any help? Pictures are in another forums wont let me duplicate.....https://www.evolutionm.net/forums/ev...e-install.html
ive never used that line for my gauges!! try using the line that gies from the top of the BOV to the intake mani on the right side of the manifold and see if that works
You can't use the line that you used. The line mentioned above is recommended. You can also use the line that goes from the intake manifold to the fuel pressure solenoid. Its just to the right of the line you tapped.
