Help installing Samco radiator hose kit
Old Oct 17, 2003 | 04:00 PM
WRC4ever's Avatar
Hey guys,
Would anyone have instructions on what steps are involved to install the samco radiator hose kit, along with an uprated cap?
I heard that if you replace the cap, you also need to change the thermostat to an uprated one. Is that true ?
What steps are involved in doing the swap?
Thank you
Old Oct 21, 2003 | 12:32 PM
QuantumEVO's Avatar
Swapping hoses?
1. Jack up left front corner
2. Drain coolant
3. Switch hoses
4. Lower car
5. Fill with coolant and check/fill as the car is warming up
I'm not trying to be smart about it, but that is essentially it. There is a petcock on the passenger bottom of the radiator; remove your rad cap first and have a big pan to catch your coolant. If you have any questions, please ask; I can be more specific in some way.
Mark
www.Quantum-Racing.com
Old Oct 21, 2003 | 12:35 PM
bovbilly's Avatar
Post Pics when Done!
Old Oct 21, 2003 | 07:42 PM
Pitbul09's Avatar
Where is the drain plug to remove the radiator fluid?
Old Oct 22, 2003 | 10:31 AM
QuantumEVO's Avatar
It is on the bottom of the radiator on the right side. There is a wingnut type screw on the back edge. When you back it out far enough, coolant starts to drain from the hole in the bottom. It has a stubby little 1/4" pipe so you can slip a hose on it to make things a bit less messy.
Mark
LVSBB6
Evo X How Tos / Installations
Apr 2, 2009 07:40 PM
extremepsi
Sep 23, 2008 03:13 PM
Jakeg97
Jan 3, 2006 11:10 AM
Chris@nolimitmotors
28
Oct 19, 2005 01:55 PM
