How to: tranny/xcase/rear diff fluid changes
Old Jun 2, 2012 | 05:16 AM
STLEVOIX's Avatar
use ATF in your xfer case?
No.
Old Jun 4, 2012 | 08:49 AM
MrJuls's Avatar
What is the ATF SPIII oil for then?
Old Jun 4, 2012 | 09:12 AM
rcheung's Avatar
The transfer case uses two fluids. One is gear oil , the other is the ATF SPIII. The gear oil is what you have to change not the acd. The mitsubishi can says LSD gear oil.
I'm not sure if the AYC fluid change in your model is similar to the X in the US. There is a drain and fill for ATF SPIII and Gear oil for the rear diff in the X.
Old Jul 13, 2012 | 05:38 AM
Honni414's Avatar
amazing write up! i would not have been able to figure this out without this thread and its pics.
i used AMSoil MTG GL-4 for the tranny and AMSoil severegear 75w90 for the T case and rear diff, i could not be happier! She shifts like butta now!
Old Jul 13, 2012 | 11:22 AM
MrJuls's Avatar
Thanks guys,i ended up using Liqui moly 75w90 for the gearbox and also Liqui moly for the t case.The shop that did it has done other evo's before so i'm sure they used the right viscosity.
Old Aug 14, 2012 | 02:16 PM
yenny's Avatar
great write up with good photos!
dumb question but "6. Pour new fluid in until it starts to come out of the drain hole (It is sideways) or around 3 quarts."
Am I pouring new fluid until it comes out of the FILL hole? meaning it's topped off?
Old Aug 16, 2012 | 05:35 PM
smoOVE's Avatar
i just pulled my motor apart and since its out im going to change the tranny and transfercase fluids... whats the best to go with?
Old Aug 16, 2012 | 07:08 PM
yenny's Avatar
redline mt90 for tranny
diaqueen lsd gear SAE 90 for tc and rear diff
Old Aug 20, 2012 | 07:20 AM
Deano_Engineer_'s Avatar
I've heard Lucus 75w90 is the best choice. Lucus makes great automotive products. That is what I will use when I change my transmission fluid today.
Old Aug 20, 2012 | 07:23 AM
For your ACD pump fuild, I talked to Vladimir Bace (creator of the ACD re-build kit) from acd-tuning, and he had said to use AMSOIL fully synthetic ATF for the ACD pump. I need to rebuild my pump and change that fuild today as well.
Old Sep 3, 2012 | 03:10 AM
quochung123's Avatar
merged quochung123 posts
guys so how many litres for trannny? how many litres for rear diff do we put in what is recommended what brand and what grade? i have an evo 7gsr its done 100k
guys does the diff and transfer case use the same oil? and what brand redline anygood/. heavy shock proof
this is for my evo 7 gsr
Is the acd the same.thig as transfercase
What is acd? And what is transfer case? I have an evo 7gsr can someone explain to me please
Old Sep 11, 2012 | 05:33 AM
Davo's Avatar
5sp is 2.9qts
Old Sep 16, 2012 | 03:11 PM
IMPdemon's Avatar
Quochung123, this topic has been covered extensively.
Do some reading before asking again, starting with the stickies here:
https://www.evolutionm.net/forums/ev...faqs-forum-61/
Old Nov 23, 2012 | 03:03 PM
benihana242's Avatar
Great write up. Very helpful the other day. I recommend the funnel for the transfer case. Makes it a lot easier than the pump.
Does anyone know where to get a good trigger style pump?
Old Dec 17, 2012 | 08:09 AM
Grimgrak's Avatar
I wonder if using regular generic atfIII has anything to do with my acd lights coming on... I just did a trunk relocation and all the wiring seems good.
