Easy way to fill tranny fluid
Old Oct 23, 2004 | 11:40 AM
  #46
justchil's Avatar
Got the rear diff changed.. it was easy.
Nm on the electric pump.
Tranny changed and transfer is draining.
Old Jun 17, 2006 | 07:04 PM
  #47
LV///R's Avatar
Tranny Help! Instant help needed....
delete this
Old Jun 22, 2006 | 06:15 PM
  #48
barneyb's Avatar
How to drain transmission fluid.....
1. Remove fill plug
2. Place drain pan below drain plug
3. Remove drain plug
4. Watch transmission oil shoot out horizonality and splash down on the far side of the drain pan
5. Go buy a large bag of oil dry
Old Nov 6, 2006 | 07:49 AM
  #49
evolucion's Avatar
After all the sayings how good redline fluids are and few freakin store I stopped by then having no luck finding any redline fluids = one unhappy driver. So after checking online at the Autozone site which listed that they have it. I thought I have some luck in finding what I'm looking for. So I asked the guy the question, do you have any redline fluid?
- uh what year?
- 2003
- uhh...75w90 this is what they reccomend
- your not helping me man, all I'm asking for is that Redline everyone seems to be talking about. <saying in my head of course.
- no we don't have
- WTF
Went back home and check online. Found some near by, OK for $11. Let see how much for shipping?
WTF $8 for freaking shipping? Reminded me of Shopping on E-Bay.
Then I started reading this thread some more and came upon this
Originally Posted by Satori
Guys! Don't use redline in your transfer cases. Mitsu recommended what it did for a reason.
what's the good for the car? at this point I don't care what
Tranny =
Differential =
transfer case =
Old Nov 6, 2006 | 06:16 PM
  #50
daisaw1219's Avatar
tranny use penzoil synchromesh....avalable at autozone for 6 bucks a quart....you need 3
differential and trannsfer case use Diaqueen avalable at your mitsu dealer for about 50 dollars a jug. both use less then 1 jug.
Old Nov 9, 2006 | 02:33 AM
  #51
gg_evo9's Avatar
for the transfer case oil, is it in red color ?? coz my car got a bottle of red fluid with < ATF III > on the cover.
Old Feb 22, 2008 | 03:42 PM
  #52
funks's Avatar
Per Road Race Engineering
For Tranny = BG Synchroshift 1 (buy 3 quarts) - uses up around 2.75 quarts
For Transfer Case = Redline Heavy ShockProof (buy 1 quart) - uses up around .6 quarts
For Rear Diff = Redline 75W90 (buy 1 quart) - uses up around .6 quarts - Note, it's the 75W90 (which comes with friction modifier), NOT the 75W90NS
Old Feb 27, 2008 | 09:24 AM
  #53
chris mccarthy's Avatar
liquids
those mentioned above, where do you get them, i know of only one source fro Redline, and i don't think they carry many products of their line..?
Old Feb 27, 2008 | 06:52 PM
  #54
6-speed's Avatar
You can get most Redline stuff online at Jegs.com.
That's where I get Redline MT-90 for the transmission.
Summit Racing sells Redline as well.
Old Feb 28, 2008 | 11:21 AM
  #55
liquids
thanks, i guess online suppliers can be located for all.
Old Apr 26, 2008 | 04:03 PM
  #56
BHB-MR.EVO's Avatar
Thanks for all the Help guys
Old May 21, 2008 | 09:17 PM
  #57
djslik408's Avatar
Can anyone post pictures of the location of the transfer case drain plug? I found the tranny and rear diff. and changed those. Now one more to go!
Thanks in advance.
Old May 22, 2008 | 01:53 AM
  #58
gmore84's Avatar
Originally Posted by simevo
This is after you have drained, cleaned and installed the drain bolt.
Get a cheap pump for $4.00 at local auto store then pump away.
got me one too.. saves money and mess.. lol.
Old Oct 26, 2008 | 10:16 PM
  #59
Tor's Avatar
Tor
Where did you buy the pump that fits redline bottle, I have a hell of time trying to find one....
Old Apr 19, 2009 | 07:33 PM
  #60
stockEvoIX's Avatar
Get a pump that pumps from a tube that'll fit in the bottle. I think you may be able to order it online from harborfreight.com if there's not one locally. Otherwise cut the bottle nozzle off with a sharp blade so the pump will fit (if possible).
